lexia to c5 x7
stevec5
lexia to c5 x7
I'm thinking of buying diagnostics for my citroen c5 has anybody had any joy hooking up to c5 x7 2.0hdi year 2010 with the lexia kits. and if so can this be used to recode ecu for new injectors. thanks
OnlineStickyfinger
- x 2008
Re: lexia to c5 x7
Mine has worked on the C5Mk1...Mk1(face) and it works fine on the X7 (2009)....but not on the Activa except for the engine ECU.
stevec5
Re: lexia to c5 x7
thanks, do you know whether I would be able to re code ECU for injectors with this.
- x 6950
Re: lexia to c5 x7
Stevec5 -
See my post on this - might be of use giving them a call:
http://www.frenchcarforum.co.uk/forum/v ... =3&t=53732
Edit - The kit I bought seems to be able to do this according to the description: http://easydiagnostics.co.uk/#/shop/459 ... t/10015520
I haven't needed to do this so can't test it for you, but I have changed the BSI configuration for some options as some values were wrong from the last muck up at the garage!
