Question for c1 owners
daviemck2006
- x 485
Ok so mine is a pug 107, but apart from headlights they are identical! It's about the clutch. I know these have a reputation for poor clutches, and the clutch on mine seems ok after 54000 miles. But, the clutch pedal is higher than the brake pedal, by quite a bit. I haven't played with the adjustment yet, as apart from this there seems no problems. If I remember correctly my last one wasn't a big difference. How is the clutches on yours?
Skoda Karoq 1.6tdi 2018
Peugeot boxer 2016
In the family
C1 vtr+ 2010 daughter 2
Peugeot boxer 2016
In the family
- x 8457
Re: Question for c1 owners
On mine l believe it's fine but after all this talk of maladjusted clutch cables I'm going to check mine.
I'll report back....
- x 1061
The clutch problems were apparently caused by incorrect adjustment at the factory , Citroen revised the adjustment procedure & there is now a very specific adjustment procedure that involves also adjusting the pedal stop aswell if i remember right. I'll have a dig around my archives tomorrow & see if i can find it.
- x 8457
Wheeler, thanks! That will be incredibly valuable to us C1/107 owners...
daviemck2006
- x 485
That would help in my case wheeler. I think the clutch is ok, but just the pedal seems very high. At 54k my one is in the region that the clutches go with the larger 190mm unit, the earlier 180 mm if not looked after can go in as little as 20k. Even tho I know Shaun has abused this car for a year, most of his mileage is in the country with little gear changing, so I'm hoping it's ok.
Peugeot boxer 2016
In the family
Peugeot boxer 2016
In the family
- x 1061
Is there a way to upload PDF files to a thread on this forum ? I have the pedal & cable adjustment files here but don't know what to do with them ?
- x 8457
Not into the forum Wheeler but they can be uploaded into a Forum Wiki article...
If you don't want to yourself then one of the admins can do the necessary for you...
