Winter storage
So, battery disconnected
or
Battery off and ECU removed (Stored in house in Antistatic bag and descant)
or
battery on and trickle charge
Winter storage
- x 1987
Winter storage
elma
- x 287
Re: Winter storage
Battery disconnected and preferably kept at room temp.
- x 8309
Re: Winter storage
Suspension should set to low to relax the sphere diaphragms... Generally spheres last longer on sinkers and this is the reason why..
Nice if you can elevate the wheels to prevent flat-spots developing on the tyres...
- x 1987
Re: Winter storage
I was thinking 50psi Jim
Any comments on removal of the ECU ?
- x 8309
Re: Winter storage
Yep, that should do...Stickyfinger wrote:I was thinking 50psi Jim
Which ECU?Stickyfinger wrote:Any comments on removal of the ECU ?
I see no need to remove any of them personally...
- x 1987
elma
- x 287
Re: Winter storage
I've never removed one for storage, Greens come to life ok but theres only the ABS And Hydractive ECUs on her.
I could knit you a nice ECU warmer, heard a rumour you've got loads of free range wool down your way.
- x 1987
- x 8309
Re: Winter storage
Only if the battery is allowed to get very low potentially Alasdair...Stickyfinger wrote:Just thinking about my previous problem
And if it does then I have my ELIT
I've stored my Activa over winter for several years in a row and let the battery get very low on occasion with no adverse reaction fro any ECU..
Ditto S1 V6s too..
Best to be happy and always make sure the battery is happy...
- x 1987
Re: Winter storage
50psi and take off the battery (keep in the house) then.
Quick one ?, does Waxoil/Dinatrol effect rubber bushes and Citroen return pipes?
ACTIVE8
- x 6
Re: Winter storage
So a Xsara Picasso in a warm garage (integral to a house with boiler in it) could have the battery left in situ.elma wrote:Battery disconnected and preferably kept at room temp.
Hmmm now the different location Citroen placed the battery in helps the battery to not get a
ACTIVA
