Help find cruise control retrofit Xantia
fv43576
x 3
Unread post by fv43576 »
My wife bought a Citroen Xantia 2.0HDI 110 SX 2001, because I have my new C5 she like the idea of suspension. She is transporter to work in London 5 days a week average 25,000 miles a year she want me to find if cruise control retrofit vacuum is possible to fit. Has anyone know the name of company and type number that can fit this car? I have found one off Ebayer
http://www.ebay.co.uk/itm/Command-Cruis ... xy0bRTFR5q
the car have a throttle cable not electric one.
x 8457
Re: Help find cruise control retrofit Xantia
You need to chat to Paul (citroenxm) as late HDis have cruise already available but there is some work to do...
Paul has done the job on one of his in the past and hopefully he'll be along in a bit with the lowdown...
If not, PM him... I'm sure he'll be delighted to advise...
x 3298
As I recall, the ECUs do have the software in them (for the HDi engines, that is), but there is some wiring to do to make it work. I believe he has done it on one of his HDi Xantias.
x 8457
That's right James. I believe the work is quite involved from what Paul was saying...
A pukka cruise stalk will be needed too...
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
Theres two ways to see if you have compatability. RP8421 OR HIGHER is firstly needed but you will also need a lexia to switch on the Cruise Option in the configuration menu..
Bosch put in cruise control software in late on ECUs, and as above you need to use a lexia to go in and switch it on. But however, by this time, Citroen did NOT modify the Xantia Loom to take advantage of this feature! So a little wiring is needed to sort it out. The main thing is you need to get 7 wires (To be safe) in from the ECU to the car, around the fuse box and steering colum. Mainly so the ECU can see the brake pedal switch, the speed up and speed down and cancel switchings from the cruise lever.
Firstly, once you know you have built in cruise... have a good read through this post:
http://www.frenchcarforum.co.uk/forum/v ... =3&t=39257
This is where I got most of my ... NO All of my information from for my car..
A very sad...
1994 XM 2.1 d auto
x 8457
Excellent stuff Paul :) thanks for responding to this post....
citroenxm
Fallen Hero
x 70
When I sold my Xantia I took the 2000 ECU and matching transponders out and god knows where the hell it is now!
Id fit it to the current Xantia exclusive I have now...
A very sad...
1994 XM 2.1 d auto
fv43576
x 3
Thanks Paul a wonderful adviser, I think I will be able to do it, if not I will send to my best friend who is high qualification work on electric cars thanks again =D> :-D
citroenxm
Fallen Hero
x 70
Your ecu is the bosch edc one... that topic gives the pin outs needed for it..
A very sad...
1994 XM 2.1 d auto
