Temperature sensor 2.0hdi
Bick
x 43
Unread post by Bick »
Hi guys,
i have a Citroen Relay with a 2.0hdi engine and i need to replace the coolant temperature sensor, the push in type. What make replacement part would you recommend or is it better to go for a genuine one. I ask as from following this site for many years it appears there are some makes of replacement sensors that are not up to scratch.
Thanks in advance for your experience in this matter.
Mark
Bick
x 43
Re: Temperature sensor 2.0hdi
I know its not a Xantia or a C5 but it still has a 2.0hdi engine in it.
Was it a daft question i asked? Or is it a case that no one has replaced the temperature sensor?
JohnD
(Donor 2022)
x 72
Unread post by JohnD »
I replaced the temperature sensor on a 2ltr 8valve engine. I got the sensor from a Cit agent and it was less than a tenner
2010 C5 X7 VTR+Nav 160
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
x 3298
You did not ask a daft question, it was just that sometimes posts take time being responded to.
Bick
x 43
JohnD wrote:I replaced the temperature sensor on a 2ltr 8valve engine. I got the sensor from a Cit agent and it was less than a tenner
Good point John ill give them a call and check, many thanks.
Bick
x 43
Hell Razor5543 wrote:You did not ask a daft question, it was just that sometimes posts take time being responded to.
Okay fair point ill wait a while, many thanks.
lexi
x 133
Unread post by lexi »
As far as a coolant temp sensor goes, any good make like Delco or similar should be fine from Ebay.
It is stuff like MAF units, electrovalves, Crank and Camshaft sensors that you need to buy genuine or OE.
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Bick
x 43
Hi lexi your advise is duly noted, many thanks.
