citroen bx 16 valve 1987 obd ?
neels
New User
Unread post by neels »
Hi, my native language is not English so there can be some faults in it.
I own a citroen bx from 1987 but it wont want to start so i want to read out the ecu for faults.
I have read that lexia 3 support the bx series.
But i cant find any diagnostic port on my car what need i to do ? For reading out the ECU.
I hope that everybody understands that i try to type as good as i can in english
x 5654
Re: citroen bx 16 valve 1987 obd ?
Your request is perfectly understandable and you are likely to have answers soon.
However, you may have a better response from our sister forum, the BX Club.
There are BX owners here but far more over there.
x 5654
Had a quick look there and only found these results
Timmo
(Donor 2022)
x 168
Unread post by Timmo »
there is a plug in the engine bay Left side as you are Looking at the engine from the front, 2 pin, if memory serves me, Grey coloured plastic, it is for plugging in,but the BX Does not have obd.
what are the symptoms of it not starting?? i have had similar issue's with my 16v in the past!
'58 C2 Code
'58 partner teepee outdoor
