for some time perhaps even years I have been having issues with serpentine belt tensioner
pulleys on my Citroen Xantia 1.9TD estate.
I've had 3 very noisy GSF pulleys which seem to wear out very quickly within 18 months
and now I have a much more expensive pulley which seems a lot quieter
without the vibration of the GSF tensioner pulleys but the bolt that secures the pulley to the engine
keeps coming loose over a period of about 6 weeks.
The car has been back to the garage once already to have the securing bolt changed
and the new pulley was fitted in June 2015, the bolt is loose again and has worked its way out
almost completely, thread lock was applied the last time the bolt came out and the old bolt from the GSF
pulley was used instead of the supplied one that came loose but the same thing has happened again.
a couple, of weeks back I started the car and there was a loud screeching sound from one of the pulleys
a particularly damp morning at the time. I even lifted the bonnet to check the pulley and it appeared to be bolted up tight
to the engine block.
Anyone had similar problems with tensioner pulleys? I would be extremely grateful for anything you
might be able to share that could lead to this little problem being sorted once and for all
as it puts my car off the road owing to the hydraulic suspension, steering and brakes
about every six weeks for three or four days and often when the car is needed most.
Thanks in advance . Nigel,
