Hello
The plastic link of the front height corrector keeps popping of. I have changed the cradle for better one , renewed the dog bone and it was good for about 3 months but yesterday it popped off again. Very annoying problem. I do not have the original holding pins of the dog bone. Is it possible that the lack of those holding pins could cause this problem or is it time to get a new cradle.
Raul
dog bone holding pins ( xantia )
Raul
Citroen gsa 1299 , 1982
Citroen gs 1,2 pallas 1977
Citroen xantia 1,9 td estate 1996
Citroen Xantia 2.0 hdi 90 2000
- x 8457
Re: dog bone holding pins ( xantia )
No, generally that's not the problem.
Often it's corrosion on the balls them selves that cause it. Corrosion reduces the ball size a little and makes the dog-bone a slightly looser fit.
Also, if you're not really careful fitting the new dog bone it's possible to start a little stress fracture in it that grows over time and makes gradually weaker and looser until it pops off...
chinkostu
- x 30
Any way of preventing this? I've got to replace the rear one on mine as it would appear the previous owner decided to cable tie it! I have a new one already but any tips will help as I don't fancy waiting 2 weeks for another in the post!CitroJim wrote:No, generally that's not the problem.
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Saxo 1.1 East coast
1999 Punto
1996 306 1.8 XN Auto
1996 Fiesta 1.3
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto
1996 Fiesta 1.3
- x 8457
A tiny smear of grease will do the trick but when I say tiny I really mean tiny...
Xantidote
- x 4
Oooops?? I wonder whyCitroJim wrote:A tiny smear of grease will do the trick but when I say tiny I really mean tiny...
I had the rusty ball problem several years ago on the rear unit, and applied a lot of grease to the new ball & the new dog bone socket, to ensure it never had any chance of rusting ever again. I've also smeared a bit more grease and oil on it on subsequent visits under the car. Despite the generous greasing, no problems up to now
Martin
1995 Xantia TDLX (deceased
- x 8457
Too much grease on the ball itself can cause a hydraulic lock in the ball cup and cause it to split Martin!
Like you I always keep plenty of grease on the external surfaces and that certainly does help keep the wet out...
Once I was a bit too zealous and got an MOT fail for it; the tester thought all the grease was a hydraulic leak!
A quick clean-up and an an explanation resulted in a pass....
Xantidote
- x 4
Ah right, understood. Thanks JimCitroJim wrote:Too much grease on the ball itself can cause a hydraulic lock in the ball cup and cause it to split
Martin
CitroenCrazy
- x 65
Just a quick one - if the underlying problem is the ball has rusted and hence shrunk in diameter, it is possible to just replace the ball itself.
Citparts sell one - https://www.citparts.at/en/products.php?id_group=144
I've fixed one of my cars this way.
- x 8457
Good find!!!CitroenCrazy wrote:Just a quick one - if the underlying problem is the ball has rusted and hence shrunk in diameter, it is possible to just replace the ball itself.
That'll do the height corrector end a treat and also fix a common problem where the old ball, which is riveted in, works loose and then comes off..
It won't help with the ball on the anti roll bar end directly but it can be used with a bit of skilled welding...
Raul
I ordered a complete new front height corrector ( 350 eur). The dog bone of the back is currently cable tied so I am going to buy this fix. Thanks for the information.
