I have few question before going on with my repair plans
Few months ago my abs light started to blink. Randomly but went off when turning car off and then on. Everything worked great. After weeks I got permanently abs light and also handbrake light. This was first time the handbrake light got on. Both didnt go away so it was a permanent error. Well then, after a while my handbrake pedals broke off and destroyed all, sencor, ring, pedals aso. from the passanger back side. I thought it might be the case why those light lighted my nights on the dashboard. I did repair my brakes. But sadly both lights stayed on. Because of handbrake and abs lights do i need to reset fault codes with a proper program (PP2000 etc.) or should it still reset by itself? I have few thousand kilometers behind so it should have do it already if it reset by itself.
I know blinking abs light without handbrake light can be caused by faulting sencor, ring, dirt and so on. Because I have also handbrake light on with abs (handbrake is working just great) should I check something else? I did clean those rings and sencors but no help. So guys - you have any idea? Any common problems or anything? Most Im interested is why my handbrake light got on too?!
My car is 406 2.0 petrol 1999.
Cheers guys!
