Xantia heater problem
- x 18
Guys ... the slider between the setting for external air and recirculated air on my S1 turbodiesel appears to have bust. It just flicks from one position to another with absolutely no resistance and no flap movement as far as i can tell. So ... what has given up and more to the point can it be fixed?I suspect my heater matrix is on the way out as well (that'll be three cars needing it done) as i spent most of last evening trying to keep condensation off the inside of the car. Not easy.
Sent from my LG-D855 using Tapatalk
Mike
Xantia Activa Dante Red MK1 (96) 121k - SORN, to be broken
Xantia Activa Silex Grey MK2 (98) 120k -SORN, ditto
Xantia V6 Silex Grey MK2 (98) 95k - non-runner
Xantia TD Storm Grey MK1 (95) 95k - non-runner
- CitroJim
- x 6204
- Contact:
Re: Xantia heater problem
Mike, this is a common problem and is caused by a kink in the cable happening because the flap has gone a bit tight...
Sadly, it's a whole dash and heater box out job to fix...
Once the cable is kinked (and you'll most likely see the kink at the slider end), it's almost impossible to unkink.
I'd be tempted to manually move the flap to fresh air in all the time by removing the blower assembly and reaching up and manually operating the flap.
- daviemck2006
- My Cars: Far too many good ones to remember. Many BL, Vauxhall, Ford, Renault, Citroen, Peugeot, and now VAG
- x 488
The recirculation of air is one thing I have never used on any car I drive. All it does for me is make the car steaming up nearly instantly, in my view very dangerous.
Sent from my SM-G361F using Tapatalk
Skoda Karoq 1.6tdi 2018
Citroen relay camper 2012
In the family
Seat Leon 1.5tsi tourer 2019 daughter 1
C1 vtr+ 2010 daughter 2
In the family
- CitroJim
- x 6204
- Contact:
Same here Davie, I have never used recirculated air.. I like mine fresh
- Stickyfinger
- My Cars: Xantia V6 ACTIVA 3ltr 24v Manual p1
Xm 2.1TD Ph2 Exclusive
AX, little Daffodil
SAXO White Mk1. Sally - x 1297
- Contact:
Depends if the Muck-Throwers are out for me or if I am behind one of those Xantia or Land Rovers running on Chip Shop Fuel
Activa, the Moose Rider
3x C5x7 Steering racks and counting
- x 18
Not what i wanted to hear but .... thanks anyway although my slider just seems to have nothing attached to it, just flips backward and forward as if attached to thin air. Possible the cable has detached completely?
Mike
- CitroJim
- x 6204
- Contact:
Worth a look Mike as a kink in the cable normally makes the slider feel a bit springy whist doing nothing...Northerner wrote: Possible the cable has detached completely?
It's good for you Alasdair... The first cures a multitude of illnesses and clears the sinuses a treat whilst the second makes you feel ravenousStickyfinger wrote:Depends if the Muck-Throwers are out for me or if I am behind one of those Xantia or Land Rovers running on Chip Shop Fuel
- Stickyfinger
AX, little Daffodil
- Contact:
the first put you off the second...
- daviemck2006
- x 488
By the time you smell the muck throwers it's too late, your past the smell and your sinuses are cleared and chip fat smell-I'm saying nothing lol
In the family
In the family
- chinkostu
- My Cars: N Xantia 1.9TD SX
03 Fiesta 1.4 Zetec - x 30
It's a good point, why recirculate the poo smell? Usually flip it across by the time i've caught a whiff and it still stinks
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Saxo 1.1 East coast
1999 Punto
1996 306 1.8 XN Auto
1996 Fiesta 1.3
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto
1996 Fiesta 1.3
Not completely impossible though Jim.CitroJim wrote:Mike, this is a common problem and is caused by a kink in the cable happening because the flap has gone a bit tight...
I managed to repair a kinked cable on my previous V6 even though it was kinked completely into a V shape.
The way I did it was to carefully straighten out the kink with a pair of pliers and also grease the cable where it goes into the sleeve to help reduce the chance of it happening again, but the real trick to prevent it happening again is to disengage the cable at the end, turn it 180 degrees and re-engage it. That way the strain on the cable when the lever pushes the cable tries to bend the cable in the opposite direction to that which the cable originally kinked, thus avoiding it re-kinking!
That repair lasted for the year or so that I kept the car...
I posted some pictures in one of my other threads unfortunately the user profile section won't let me browse my file attachments to find it. (It says attachments are disabled on the forum)
Simon
1977 G Special 1129cc LHD
1978 CX 2400
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
- Stickyfinger
AX, little Daffodil
- Contact:
Boden cables due to internal drag are really designed for a slow constant movement.........do not shove them across quickly to avoid kinking of the inner cable....
Also don't try to adjust that flap while the fan is on full speed! That's the usual cause of failure. There is so much air pressure from the fan on full speed that it actually prevents you from moving the flap in one direction - if you try to force it against the full speed fan you will eventually get a kinked cable.
So it's important to avoid adjusting it when the fan is on full speed because even with my 180 degree tweak the cable will be weaker than it was when new. After repairing mine I avoided doing this and did not have any further problems.
Simon
1978 CX 2400
1978 CX 2400
- CitroJim
- x 6204
- Contact:
Well done Simon I must confess no success at all with the ones I've tried to fix despite trying your technique...Mandrake wrote: I managed to repair a kinked cable on my previous V6 even though it was kinked completely into a V shape.
I hope that'll give you some hope it can be fixed Mike!
