LPG! Problem
LPG! Problem
[:)] Hi all! Got a berlingo running poor on Gas, it runs good on petrol. Can't get any fault codes as of yet, i have been told it could be a gas pressure problem . Anyone had similar fault and maybe point me in another direction?!! Cheers.
If the car runs fine on petrol - then obviously you have a problem in the LPG evapourator (regulator).
Modern mobile LPG equipment is a lot more refined/complicated than the simple engine intake vacuum regulated LPG evapourators used back in late '70-es & early '80-es.
It's booking time for your LPG specialist garage [:)]
I would'nt dare touch it [:I]
- sure you aint simply out of gas ?
- used any gas station - not tried before - lately ?
Back in ancient time I drove an LPG car - and it happened that the filler valve was wet - then freezed up and leaked - even though it's supposed to be a safety double valve.
[quote]<i>Originally posted by AndersDK</i>
<b><b><b><b>[[:)] Thanks for your replys! I will try again tomorrow for a read on the codes. Its a newish 2002 , factory fitted system on a 1400cc berlingo. As you suggest a LPG Specialist is proberly next in line! I will post when i have got the problem sorted. [;)]]</b></b></b></b>
Sorry not related to your query... but how did you read the ecu fault codes on the berlingo monkeyman? it sounds too good too be true! I presume you must be grounding a wire on the diag port forcing the ecu into some diagnostic mode which flashes the ecu light ??
Any info most appreciated as i'm getting closer to torching the damn thing!
Cheers
Cheers
[:)] Hi davey. The diagnostic socket for the LPG is under the bonnet on the nearside.Its a 2 way black connector and u earth out the wire on pin2 with the ignition on. It then flashes a number of times and you read the code from that and match it to a fault code legend. The diag socket for the LPG is different from the 16 way diag socket which is in the car. You need a proper diagnostic tool to read codes from that socket.
Hope that helps..............my LPG still runs rough!![:)]
