Hiya I'm new to this forum and I'm hoping someone can help me . I'm a proud owner of a Citroen c5 diesel 1.9hdi 2003 automatic I had a water pump and cam belt fitted yesterday the job was done and the car started on the button I drove it for approximately two miles then the engine started to knock and sounded like it was only runnin on three cylinders then lost all power and cut out altogether and the heater motor suddenly stop workin as well don't know if that as anything to do with the problem as well please can any one help .
Kind regards Eddie
Citroen c5 diesel problem
eddie567
lexi
- x 134
Re: Citroen c5 diesel problem
And the person who fitted the belt? what do they have to say?
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
eddie567
The mechanic that fitted the parts is scratching his head and is mystified he don't no what the problem can be he's sayin because it started and drove a couple of miles it isn't nothing he's done wrong but it sure sounds like it to be honest.
JohnD
- x 72
If he didn't tighten the tensioner pulley correctly, the belt would slip after a couple of miles and the timing be lost - just for starters!eddie567 wrote: he's sayin because it started and drove a couple of miles it isn't nothing he's done wrong .
2010 C5 X7 VTR+Nav 160
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
eddie567
That's what I've told him he came straight out to me when I broke down he pulled the timing belt cover of and because the belt was tight he dismissed the assumption the belt had slipped it funny it all went wrong after he fitted a new water pump and belt and only tipext the pulleys up to put back in the right place .
dnsey
- x 19
I have direct experience of an HID engine running a couple of teeth out (rather roughly), and then for a hundred miles or so with corrected timing before breaking a cam follower. Presumably the rocker was weakened initially but kept working for a while.
Don't ask who fitted the belt
I wonder if this is a similar scenario.
eddie567
Hello dnsey my car started on the button drove for about two miles then just gave up and won't even turn over now sound like its locking up when trying to start it but I've been advised not to try and start it until my mechanic as had another look at it yes I had a professional do the job and he's still stuck for an answer.
lexi
- x 134
I would ask him to do the belt again by locking the timing with the pins and making sure the floating crank sprocket is bang on in the middle of woodruff key.
It just may be a tad out on timing.
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
dnsey
- x 19
Once the belt's fitted, it's necessary to turn the engine over a couple of times manually to equalise the belt tension, and to re-check the timing. It's surprising how far out it can be.
eddie567
Thankyou everyone for your help . Does anyone know where the timing marks are ?
Kind regards Eddie.
Kind regards Eddie.
lexi
- x 134
They are not in view eddie. If you want a good fiddle with some spannering then it can be explained.
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
- x 8330
There are no timing marks as such Eddie, indexing pins are used through the cam sprocket and flywheel to lock both securely.
It really does sound as if the timing has slipped badly but normally damage is limited to just broken cam followers. I would think the garage must take responsibility if the timing has slipped. The HDi has a manual tensioner and does need care in adjustment and setting up.
Let us know the outcome.
eddie567
Hello my Citroen c5 1.9 hdi horn as suddenly stopped working any ideas guys many thanks Eddie.
- x 8330
Eddie, it's best to pop this question into a new thread...eddie567 wrote:Hello my Citroen c5 1.9 hdi horn as suddenly stopped working any ideas guys many thanks Eddie.
eddie567
O ok jim I'm afraid I'm new to this thankyou for your advice Eddie.
