whats these cables for on a xantia
natace1972
Unread post by natace1972 »
they are under the gear lever cover,there are two one with white plug on end and other green with plug they are running to the back of the car but not connected to anythink under the gear cover
xantias a 1993 sx ver
Homer
x 16
Unread post by Homer »
Sounds like the connectors for heated seats (switches just in front of gear lever - on later models anyway). The SX has electric rear windows. They often put a standard wiring loom in across the range because it is cheaper than adding bits of loom to the higher spec models.
natace1972
the elec windows are working in the back so dont know if its that, how would i find out if it is the heated seat wires and would an l reg sx xantia have these but not connected
Dave Burns
Unread post by Dave Burns »
There should be numbers printed at intervals along the cables length, see if you can spot them.
Dave
natace1972
no numbers that i can see as covered in a foam covering,all i can say is that the green one is alot bigger than the white one
natace1972
anyone know for sure what these are for
AndersDK
Unread post by AndersDK »
Nat -
As Dave explains - you need to identify the wires by their numbers printed on.
The Xantia Citroen generation of cars uses these prints for cable identification - unlike the earlier Citroens with coloured markers.
The id numbers can then simply be traced from the Xantia electrics schematics.
And you can trust Dave - he knows [;)]
