We have purchased a Peugeot 3008 1.6hdi Active manual on a 12 plate with 17000 miles ,on test drive didn't really notice anything amiss,but there is a slight squeak of the clutch pedal when depressed,have looked under dash and there is a spring,could this be the culprit ? Has anybody else had a similar problem ? Any fixes ? Lovely car by the way
Peugeot 3008 clutch pedal
davo77
Hi,after having a Citroen C5 for 10 yrs we thought a change of car was in order
C5 lx 2.0hdi 04 114k, Saxo 1.1 desire 02 83kk,Peugeot 3008 1.6hdi Active 17k
- x 1240
Re: Peugeot 3008 clutch pedal
My 406 sometimes makes a little squeal when you engage the clutch but its been doing it for the last 55k miles and doesn't seem to have got any worse.
Gibbo_Wirral
Try a bit of this on the spring and pedal linkage:
http://www.toolstation.com/shop/Automot ... ase/p10203
Peugeot Planet Diagnostics: Wirral, Merseyside, Lancashire, Cheshire, North Wales
davo77
Thanks for replies chaps,have sprayed all bushes/ link's around clutch pedal under dash with grease and still the same,when pressing by hand it is almost certainly the spring itself, when pressing pedal slowly it must be designed like it, a French querk .
