Replacing engine
Replacing engine
When replacing an engine with a complete used engine is there anything to do with the ECU? Does it need to be mapped to the injectors and if so is this the only mapping required. (C5 163 bhp 2.0 hdi)
- My Cars: M reg Xm S2 2.1td Auto Exclusive. 269k and rising
L reg XM S1 V6 12v Manual SEi
L 94 XM 2.1 TD auto total resto
2008 Peugeot 207 Sw 1.6 16v hdi. 217k and rising
2010 Peugeot 207 SW 1.6 8v HDi 161k and rising - x 71
Re: Replacing engine
No.. I dont think so. I know The 8v 2.0 hdi engines dont need injectors matching.. Not sure of the 16v engines though.
Can you not recover and swap injectors from the old engine?
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
Yes i could swap them - do you know whether the ECU needs telling any other sensors have been changed.
No nothing.. IT doesnt read them like that.. Just control them...
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
IIRC one of the ECU's, maybe BSI or Injection, has the engine serial code on it, I've seen it somewhere but can't recall which one.
Also if your using a brand new exchange unit or bottom end, if the engine code is one of the newer ones that may need changing as well.
Is it used or new?
Dare i ask how much?
Is it used or new?
I'm looking at a used engine complete with all its attachments. Both engine types are the same - rhh. Same year as well. If I was to nothing to the ECU what would be the effect.
Nothing.. stick it all in. The key and bsi unlocks the ecu and the ecu controls the engine. It will be fine. The worse case it will need just the four injectors swapping over!
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
Thanks for the useful advice - can the injector mapping be accessed with lexia leads/software, I was looking at buying diagnostic software. Does anybody know whether the leads on eBay from China are kosher.
The China systems are hit n miss... some leads are good, some are crap!!
I dont think lexia can access Mapping, I caertainly havent. They can see injector programming though. Its more diagnostic repair rather then tuning up etc..
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- waynedance
- x 8
Swapped my 2.2hdi 16v and did not Have to code.
Sent from my LG-H815 using Tapatalk
Volvo S80 D5.........
Do you know of any good sources for the lexia system. If the injectors aren't mapped does it make any noticeable difference to running or is it just an economy tweek.
