Hello I have a 2006 607 2.2hdi(170). I was getting a lot of trouble with faults all coming on at the same time. Dpf seat belt pretensioners brakes,power steering,immobiliser. It was traced back to a faulty injector on number 1 cylinder which was replaced. And in doing so it spiked the ecu. I have sent the ecu to a specialist and they have confirmed this. The only way I can sort this is if I had another ecu from a scrap car which I would then be able to get cloned from my original ecu. There are not many of these cars about and cannot source one here in Northern Ireland.
It is a Bosch ecu number
0281012478
I would be eternally grateful if one of your members could help me source one as my car has been off the road for nearly two months
Thank you
Replacement ecu
BX
- x 19
Re: Replacement ecu
Just did a quick Google search. This outfit will send you a replacement for 400euro. They will refund 50 if you return the old unit to them within 30 days.
http://www.proplus-technologie.fr/calcu ... -4452.html
They will clone it for another 50. So I assume that if you return your old unit for cloning the price remains €400.
I know nothing about them.
- x 8422
Re: Replacement ecu
