Citroen Picasso Problem
TG KOPITE
New User
Unread post by TG KOPITE »
Hi, I have a Citroen Picasso, 2004, 1.6hdi. When I put the key in the ignition and turn the key to position 1 the dash lights up, when I turn it to position 2 the lights go out. Does anyone have any idea what I could do? Thanks in advance
addo
Sara Watson's Stalker
x 95
Re: Citroen Picasso Problem
Unread post by addo »
Hi, does it start and run, what happens to the dash display if it does?
TG KOPITE
New User
When the key is at position 1 the battery light is on, turn the key to position 2 and the dash is blank then beeps. It was running fine
x 1240
Unread post by Peter.N. »
Is it still running? If not check your battery connections ... or the battery.
old-un77
Unread post by old-un77 »
Nothing to do with the day/night dash settings is it?
button on the left of the dash.....with a moon symbol?
depends on which beep............three beeps summat like handbrake on
didly didly didly lights on, ign off/key removed
key in ignition with drivers door open............
