Hi Folks, noticed yesterday that my +ve battery clamp has split. Its looking a bit done anyway and in light of the publicity on here want to change it.
It looks like the last inch of the lead is encased in "lead/solder" sleeving running into the clamp and that the replacement clamps down at my factors are all cable clamp types.
Do I have to cut the cable at the start of the "lead/solder" bit and then attach the new clamp to that or is there a way to remove the "lead/solder" bit? Worried I might end up with a lead that is too short.
Many thanks
Alan
Changing Xantia +ve Battery Lead
- x 1240
Re: Changing Xantia +ve Battery Lead
You may be able to buy a lead complete with connector, if not you can get a screw on connector. Have a look on ebay.
elma
- x 287
I had the same issue exactly on my Xantia. I didn't need to replace the cable, but when the old terminal was removed the cable within was blackened. I just bought a slightly longer terminal, snipped an inch off of the cable and it fitted back together well.
In hindsight I'd just make up another soldered one though, the screw up connectors strain the wires. The solder connectors do still exist, just a bit harder to find. Example here Buying a pre made one may be preferable, I think the reason I didn't was the longest one in Halfords didn't reach.
ecohouse1
- x 3
Thanks - I will look at the complete lead option I think. This is to on a 1.9TD 1999 with the XUD. Anyone know the length to go for? I take it that it bolts to back of the starter at the other end. I notice that a couple of other cables join into it. Do I just connect them via a ring terminal on the clamp bolt?
Cheers
Cheers
chinkostu
- x 30
It will have 3 ends, one on the battery, one to starter and last to fusebox. I'll see if servicebox shows a length
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Saxo 1.1 East coast
1999 Punto
1996 306 1.8 XN Auto
1996 Fiesta 1.3
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto
1996 Fiesta 1.3
ecohouse1
- x 3
I am confused
, how would I contact the lead to the starter and fusebox if the replacement lead just has a connector to the battery post at the top and ring connector to the starter? Would I Have to get a specific lead from Citroen UK?
- x 1240
