Xsara 2.0 Hdi - STOP warning
smoker
Unread post by smoker »
Occasionally while driving the car flashes up the STOP warning on the dashboard, along with the light in the engine temperature gauge. Sometime the cooling fan runs when this happens, but not always. There are no other symptoms - engine temp and coolant level are fine and usually switching the engine off and restarting clears the fault. Hasn't done it for a while - in fact over summer, but did again this wet morning, leading me to suspect a dodgy connection. Is this a known fault - any ideas where to start looking?
Many thanks
52 reg Xsara 110 hdi
mardybum
Re: Xsara 2.0 Hdi - STOP warning
Unread post by mardybum »
Last I enquired about this specific issue, its something to do with the AC system.
I'll have a look around to see if I can find the answer again...
mardybum
JohnD
(Donor 2022)
x 72
Unread post by JohnD »
One of my daughters ran a Xsara 2ltr for a lot of years. At one time she sometimes found it showed the stop light together with the temperature gauge reading high. I changed the temperature sender in the end of the cylinder head and all was well afterwards.
2010 C5 X7 VTR+Nav 160
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
smoker
Thanks for the insight guys. The connection with the demister setting makes sense, but will need to check the fans as I believe they both run when required. Will also investigate the temp sensor - I might try to get some resistance figures to see if I can test it in situ.
Thanks again.
x 1503
If the gauge is reading OK, then it will be the fans - there is only 1 temp sensor, so if the gauge is OK, so is the sensor.
