I think it's in the engine bay fuse box but without a Haynes or handbook I don't have a clue
Xantia V6 fuel pump relay location
KP
- x 27
Does anyone know where it is and which pin supplies + voltage to the pump?
- x 8327
Re: Xantia V6 fuel pump relay location
It's one of the two big double relays next to the ECU Will..
Here's a Wiring Diagram of the Injection ECU and related items for an S1 V6.. The S2 will be similar..
Double relays are items 1304 and 1307...
Hope that helps...
Hope that helps...
KP
- x 27
Cheers Jim
Mandrake
- x 694
The two relays are identical so you can swap them over to rule out the possibility of a faulty relay. Of course doing so would transfer the fault onto another circuit causing something else to fail!
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
1978 CX 2400
KP
- x 27
Just looking to apply power to test the fuel pump, and then empty the tank if it works before cutting the tank free and using it on a project with pump intact
If i cant get it to fire off the relays by shorting them tomorrow i'll just apply voltage on the connect plug at the tank end
