C8 2.2Hdi power and throttle
h2ocooler
Unread post by h2ocooler »
Hi All
Had my C8 for a while now, had the same fault since I bought it but only really just getting round to sorting it out.
1. Lack of power, it will rev above 3000 so not in limp mode, sometimes it is worse than others but there is no pattern to it, it will pull but runs out of steam around 3000.
2. The throttle (or engine revs) seem to stick for a while when changing gear so when you dip the clutch the revs rise quite a bit BUT it wont always do this.
I have had it on my lexia and there are no fault code showing up, DPF is around 675km between regenerations and pressures are good for it, fuel rail pressure are near enough the set values, fuel and air filters have been changed.
Any thoughts?
Rob
2005 Renault Laguna II Sports Tourer Initiale 2.0 Turbo Auto Estate
2003 Citroen C8 2.2Hdi Exclusive Captains Chair
2007 Renault Megane 1.6VVT Cabriolet Coupe Dynamique
02 C5 2.2 Hdi Exclusive Auto Estate (my Dads) DE_FAPPED
h2ocooler
Re: C8 2.2Hdi power and throttle
Any help or suggestions would be good thanks
lexi
x 133
Unread post by lexi »
Have you checked throttle cable function for freeplay?
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
