Water pump leak? 2.0HDI 90
Oliver53
Unread post by Oliver53 »
Hi guys,
My 2.0 HDI pic has developed a coolant leak recently and I have to top up every 2 weeks or so. With the undercover removed, after a night I can see fluids (feels like coolant) on the right corner of oil sump and on the floor, see the picture. I reckon this must be water pump failure, or other thoughts?
The water pump was changed together with timing belt and tensioners 2 years ago at 87K, now the car is 104K on the clock. Can that be gone so quickly?
Cheers,
Chang
2000 ZX 1.4i
2006 Xsara Picasso 2.0i
2011 C5 2.3i (EW12A)
2003 Xsara Picasso 2.0HDi
1985 2CV6 Special
lexi
x 133
Re: Water pump leak? 2.0HDI 90
Unread post by lexi »
If it is coming from centre spindle bearing, then the pump is kaput. If from perimeter of pump, then the flange gasket is gone ,or it's set screws need tightened
You will need the cambelt covers off to see. The pump could go in that mileage....if it is not a top spec one.
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Stewart(oily)
x 35
Unread post by Stewart(oily) »
Take the belt covers off to make sure, water has a habit of running around and coming out in the most unlikely places.
Oliver53
lexi wrote:If it is coming from centre spindle bearing, then the pump is kaput. If from perimeter of pump, then the flange gasket is gone ,or it's set screws need tightened
Thanks lexi. I'll do the check as soon as i have time...
2000 ZX 1.4i
1985 2CV6 Special
Oliver53
Stewart(oily) wrote:Take the belt covers off to make sure, water has a habit of running around and coming out in the most unlikely places.
Thanks Stewart. I'll have to leave it for now coz my poor pic has failed MOT yesterday with a few brake problems and "exhaust major leak" :roll:
2000 ZX 1.4i
1985 2CV6 Special
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
Dont leave it leaking for too long. Id also vote water pump. If water continues to get on the cam belt that will end up kaput.. It will be wise to fit a belt and pump when you get to it. The tensioners will be ok..
A very sad...
1994 XM 2.1 d auto
Oliver53
citroenxm wrote:Dont leave it leaking for too long. Id also vote water pump. If water continues to get on the cam belt that will end up kaput.. It will be wise to fit a belt and pump when you get to it. The tensioners will be ok..
Cheers I'll look into it as soon as I get the brakes and exhaust fixed 8-[
2000 ZX 1.4i
1985 2CV6 Special
