reset an Electro Mechanical Miles recorded to Zero
x 1987
Unread post by Stickyfinger »
Does anybody know if/how to reset an Electro Mechanical Miles recorded to Zero ?
I have to change my French KMPH Speedo (at present only the face is changed to fool the MOT man) to a MPH one.
I have sourced the correct V6 type in MPH ( I love you Jim :) ) but I would like to reset that to either zero or to the correct KM/MPH.
I will naturally inform DVLA of this act. It would be nice to zero it. The unit is a V6 version
addo
Sara Watson's Stalker
x 95
Unread post by addo »
You want to reset a mechanical reel odometer to zero? Is that the question?
x 1240
Re: reset an Electro Mechanical Miles recorded to Zero
Unread post by Peter.N. »
I would think that if you remove the shaft with the 6 gears that drive the drums you should be able to wind the drums back - or forward.
addo
x 95
There's a little more to it than that, but they're not super difficult. What takes some practice is getting all the drums to line up correctly once they start to turn over.
I suggest making up a dummy driver with a drill and speedo sender for testing as you go.
x 1987
Top pic....far left, there is a Key wheel, this gets set first, the others fall inline after you pop both shafts...
it seems....still to test. :)
x 1438
Unread post by xantia_v6 »
I seem to remember a pro trick is to set the wheels for 999998 or similar so that they all line up nicely when they roll over to 0.
x 1484
No need to tell DVLA - it's not actually an offence to 'correct' a vehicle's mileage - it is however an offence if, when you sell it, you misrepresent the mileage.
dnsey
x 19
Unread post by dnsey »
I believe you're supposed to write the date and actual mileage on the back of the speedo - wherever that is these days!
x 1987
It was recorded on the MoT as KM traveled for the first registration......but that is a good thing to do I think along with making a note to keep with the cars history.
So, who wants to believe my car has done 2,500 miles since new :)....I can see the ebay description, maybe I will get a good price :)
Honest Ali's Car Sales.....hehehe
