Xantia high pressure regulator seals
xantos
x 10
Unread post by xantos »
Does anybody maybe know the dimensions of o-seals in the high pressure regulator? Mine is leaking a bit and I want to reseal it...
Xantia Break 1.9TD (jammed b****!)
Xantia Activa 2.0 TCT + LPG (1998) (peeing b****!) RIP
Xantia Activa 2.0 TCT (1998) (burnt b****!)
Xantia Activa 3.0 V6 (1998) (not a b****! yet :-D )
C4 Exclusive 2.0 HDi (gear shifting b****!)
xantos
x 10
Re: Xantia high pressure regulator seals
xantos wrote:Does anybody maybe know the dimensions of o-seals in the high pressure regulator? Mine is leaking a bit and I want to reseal it...
Do a little googling xantos! :roll:
http://www.xmclub.nl/sites/default/file ... hims_0.pdf" onclick="window.open(this.href);return false;
So I guess 29x34,5x2,7 and 33,2x37x1,9 are the right ones for resealing the regulator. Of course they need to be made out of viton...
x 3298
While I cannot confirm this, I believe that some of the seals are the same size as the sphere seals (I think I have read this on the forum). If I am right then these would be of the correct materials.
kenhall1202
Unread post by kenhall1202 »
I bought my Viton seals from ebay a while back. Sizes as follows:
Cut out spring cover, 33x2x37mm
Cut in spring plug, 29x3x35mm
Ken Hall
