Screen Demister vents....for an S1
x 1980
Unread post by Stickyfinger »
Hi guys......
Screen DE-mister vents, the two black inserts on the top of the dash
Anyone got a set for an S1 car (S2 cars a different)....both of mine are cracked as are the ones in my donor car.....driving me nuts :)
I cannot think why you would have them but if you do or are going into a scrap yard (my locals only have S2 cars) and going to the Chevrons Rally....I would be happy to fork out for them.
Cheers
x 2943
Re: Screen Demister vents....for an S1
I've got two new vents here one for a C5 one other for I'm not sure, part numbers are 8265G7 and 8264L7 I have photos somewhere on my computer if you're interested I'll look them up and post them.
x 1980
Sorry mate, I should of said....for a Xantia S1
They are also "handed" left/right btw
x 2943
Ok. I think the other one is for a Relay so no luck there. :(
x 1980
Cheers for the look mate
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
Sticky...
Yes.. This could be quite possible... Im sure ive got two s1 dash left lieing around. Ive got an air con s1 dash to go on my s1 xantia which has a non air con dash in it with missing glove box..
So.. If they will come out ok ill do my best to get them out for you...
A very sad...
1994 XM 2.1 d auto
x 1980
That would be great.
I do not think any repair will work very well as the thermal shock of the heat/cold cycle will split them again even if I glue/staple pin/melt them. I do not think the brittle type plastic will cope with a section that is harder than the rest (chemical metal type) as that will just get it twisted as it heats up.
Are you coming over to the Chevron Rally ?
Do you need any bits off my S1 donor for your S1 car ?, a lot of the dash does not fit a LHD car so I will have little need of many of the parts.
Lift the cabin edge first in the middle and work outwards to one edge, once one end is free slide it sideways and it comes out ok
Xantia97
Unread post by Xantia97 »
Alasdair, is the Xantia you are working on LHD or RHD?
1997 Xantia 1.9TD LX (owned for 14 years) - Snoopy
Gone but always remembered
GS Pallas
GSA X1
AX - bad mistake!
ZX 1.9D
3 x Opel Manta
Old-Guy
x 24
Unread post by Old-Guy »
I might have saved a pair of vents from the VSX I scrapped - dismantling became a mad scramble over the last day, I just chucked anything small, potentially useful and easily removable into yet another box. I'll be bringing the lot to the Chevron's Rally - see you there.
If you've got a spare sunroof motor unit, we can do a deal - doesn't matter which of the three types, they should all be interchangeable. Easy enough to check and test. It takes less than 5 minutes to remove and not much more to fit. Despite what the BoL says, it's easy, even servicing a sunroof isn't difficult, just takes a bit of time to do thoroughly.
See you tomorrow.
Guy
x 1980
OK....will remove it a bring it up.....cheers
Old-Guy
x 24
Alastair
I now have to confess that, having sorted through the crates of bits while loading the car, that a pair of vents isn't among them. Front grill in Mauritius blue; ECUs; complete set of exterior lights, mock wood switch panel and matching face vents; hydractive electrovalve with sphere, pair hydractive front spheres little used, unused rear centre sphere; 3/4 of a set of lock barrels with key (passenger door barrel missing) and loads of other stuff but no screen vents, sorry.
Guy
elma
x 287
Unread post by elma »
If you don't find a set you can have the ones from red when I sort out green. Could be a while though.
x 1980
Not to worry guys....I took up the hobby of plastic welding and metal pinning today.....Think I have fixed them...cannot get them to seat flush atm :(
With work this afternoon, not been able to get that motor out yet, later tonight I hope or just before I leave tomorrow......if not it will be OK to send or drop off on a trip to Lyimington to see my Cuz.
chinkostu
x 30
Unread post by chinkostu »
can't even find them on servicebox you know!
they're not different for left handed models are they?
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Saxo 1.1 East coast
1999 Punto :oops:
1996 306 1.8 XN Auto :?
1996 Fiesta 1.3 #-o
x 1980
Nope....but they are handed left and right.
