Xantia - Replacing fuel injectors
lancia58
(Donor 2022)
x 8
Unread post by lancia58 »
Hi
I have a Xantia 2.0 16v make year 2000 ( RFV engine ) . I want to replace the fuel injectors. I wanted to detach the fuel rail I removed the 4 bolts that secure the fuel rail. Then I tried to detach the fuel rail with the injectors but it looks like the injectors are stacked in the engine. I was sure that after removing the 4 bolts the injectors with the fuel rail will easily detached. I tried to apply force to detach the injectors from the engine but I was afraid to break the injectors or the fuel rail. Should the inlet manifold be removed in order to detach the injectors ?
BTW I detached a fuel rail of a Xantia 1.8 16v and the injectors came out easily .
Can anyone help me with replacing the injectors of the RFV ( 2.0 16V) engine ?
Zohar
Xantia 2.0 16V Automatic make year 2000 LHD
Citroen C4 THP Automatic make year 2009 LHD
Citroen C4 VTS 2.0 16V make year 2006 LHD
lancia58
(Donor 2022)
x 8
Re: Xantia - Replacing fuel injectors
Did the fact that I did while the engine was a bit hot has any effect ? Should I wait till the engien is cold ?
x 8191
The injectors should come out easily enough, as you know from your other removal job.
They're only held in by the O rings and I suspect this is the problem; the O rings have likely gone very hard...
lancia58
(Donor 2022)
x 8
Thanks Jim. So if I'll pull hard enough the injectors will come out ? Is it better to do it while the engine is cold ( over night ) . Using long nose pliers to detach the injector one by one can help ?
Old-Guy
x 24
Unread post by Old-Guy »
As a general rule, stuck injectors are more likely to come out of a hot engine than a cold one due to the greater expansion of aluminium than steel.
Cola is a good penetrating fluid where aluminium is involved as the acid in it dissolves aluminium oxide (just think what it does to your teeth :shock:). One trick is to get the engine hot, remove the injector clamps, then trickle a little Cola down the outside of each injector in turn. This may have to be repeated. Cooling the injectors make them shrink slightly - the object being to crack them off the seals. If the injectors sit in wells, mop up the cola before actually pulling the injector out.
x 1412
Unread post by xantia_v6 »
I think we are talking about a petrol engine here, so there is no metal to metal contact, just the rubber seals which go hard.
lancia58
(Donor 2022)
x 8
Hi
Replaced the injectors today with new ones ( got set of genuine four from a local dealer ) wonder if it improves the MPG
Zohar
x 8191
Hope so!
