MyTimingBelt.com
xantiagreen
MyTimingBelt.com
Just had a wander round this site and obviously searched the xantia hdi and the site informs change at 100k or 10 years. One less bill for the next 4 or so years if it's reliable info.
Faz
90 Ax 1.0 Red
90 Bx 1.7 TZD Green
92 Bx Gti BRG
90 Bx 16v Cream
96 Xantia 2lt 16v Sx Olive green
01 Xantia 110 Hdi
Storm Grey (SOLD 4/11/18)
Temporarily driving Polo 1.9sdi
All I want is a Bx Gti or 16v!
90 Ax 1.0 Red
90 Bx 1.7 TZD Green
92 Bx Gti BRG
90 Bx 16v Cream
01 Xantia 110 Hdi
- x 8391
Re: MyTimingBelt.com
That's the recommended interval but it's better to do them more frequently for peace of mind... The HDi is a VERY easy belt to do.
I tend to be very conservative with timing belts and I'd do it at half that interval personally...
Harlequin
- x 23
hmmm is that site correct? as for my 1.9TD synergie it says 10 years as well!
Simon
- x 8391
No, that's not right.... I can't recall exactly but 60K I believe...Harlequin wrote:hmmm is that site correct? as for my 1.9TD synergie it says 10 years as well!
In case of low mileage I believe timing belts should be replaced on a time basis like tyres - 5 year intervals?
Harlequin
- x 23
- x 1052
Just remember unless you have had the car since brand new you can never be 100% that its not been clocked, the car may have an extra 30k miles on it you dont know about. I always do a timing belt on any car i get regardless of milage, age or history.
JohnD
- x 72
In the days when I had a Xantia I recall the interval being 72K (54K in poor conditions) or every five years.Harlequin wrote:hmmm is that site correct? as for my 1.9TD synergie it says 10 years as well!
2010 C5 X7 VTR+Nav 160
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
Old-Guy
- x 24
I replaced the original belt on our 1.9TD (different but very similar engine) very shortly after buying her at 11 years and 67,000 miles. Showed it to my mechanic friend (another Jim!), "You were bloody lucky, I've never seen an unbroken belt that bad!" and he's done many hundreds. His firm suggest that, regardless of make or engine, it's wise to replace belts at 5 years or 50,000 miles; as part of a pre-sale service they always replace belts not known to be well under this.
The service book for my Xantia states 10 years or 72,000 miles - probably why the first owner sold her after her local Citroen agent told her how much they'd charge for belt, and tensioners plus a set of spheres, flush and LHM (probably more than I paid for the car!).
Also be aware that things like water pump, crankshaft pulley and tensioners all need inspecting at the same time. If O.K. at 100,000 miles, it's expecting far too much for them to still be OK in another 10 years or 100,000 miles.
A failed belt, pulley or tensioner will cause a lot of expensive damage that may cost more than the car!
xantiagreen
My 110 hdi was changed at 72k before I bought it receipt says:Old-Guy wrote:I replaced the original belt on our 1.9TD (different but very similar engine) very shortly after buying her at 11 years and 67,000 miles. Showed it to my mechanic friend (another Jim!), "You were bloody lucky, I've never seen an unbroken belt that bad!" and he's done many hundreds. His firm suggest that, regardless of make or engine, it's wise to replace belts at 5 years or 50,000 miles; as part of a pre-sale service they always replace belts not known to be well under this.
Also be aware that things like water pump, crankshaft pulley and tensioners all need inspecting at the same time. If O.K. at 100,000 miles, it's expecting too for them to still be OK in another 10 years or 100,000 miles.
5.8 hrs at £35 labour £233.45
cambelt kit £63.10
water pump £23.29
red anti-freeze 4L £19.55
front pads £34.21 Total £373.60 inc vat at 15% carried out on 29/10/2009, is that a reasonable price for the work. Carried out by a company in Wolverton Milton Keynes.
This was done 29/10/2009 at 72k, cars now on 116700 and 6 years since change. I guess I will have to start saving for the cambelt and hopefully get it done for start of next year. Does the C8 hdi have the same engine as the xantia hdi, spoke to mechanic today about C8's and he mentioned the belts erode and snap prematurely due to water ingress.
Faz
90 Ax 1.0 Red
90 Bx 1.7 TZD Green
92 Bx Gti BRG
90 Bx 16v Cream
01 Xantia 110 Hdi
90 Ax 1.0 Red
90 Bx 1.7 TZD Green
92 Bx Gti BRG
90 Bx 16v Cream
01 Xantia 110 Hdi
xantiagreen
Next car I buy I'm gonna try my best to recover cambelt fitted cost if they can't show it's been done at required intervals....wheeler wrote:Just remember unless you have had the car since brand new you can never be 100% that its not been clocked, the car may have an extra 30k miles on it you dont know about. I always do a timing belt on any car i get regardless of milage, age or history.
Faz
90 Ax 1.0 Red
90 Bx 1.7 TZD Green
92 Bx Gti BRG
90 Bx 16v Cream
01 Xantia 110 Hdi
90 Ax 1.0 Red
90 Bx 1.7 TZD Green
92 Bx Gti BRG
90 Bx 16v Cream
01 Xantia 110 Hdi
xantiagreen
I can imagine mytimingbelt.com's inbox is flooded with "my belt snapped 5 years or 50k too soon"Harlequin wrote:hmmm is that site correct? as for my 1.9TD synergie it says 10 years as well!
Faz
90 Ax 1.0 Red
90 Bx 1.7 TZD Green
92 Bx Gti BRG
90 Bx 16v Cream
01 Xantia 110 Hdi
90 Ax 1.0 Red
90 Bx 1.7 TZD Green
92 Bx Gti BRG
90 Bx 16v Cream
01 Xantia 110 Hdi
xantiagreen
In the days that I had a bx I recall just adding fuel and giving it death, timing belt, what's one of them!JohnD wrote:In the days when I had a Xantia I recall the interval being 72K (54K in poor conditions) or every five years.Harlequin wrote:hmmm is that site correct? as for my 1.9TD synergie it says 10 years as well!
Faz
90 Ax 1.0 Red
90 Bx 1.7 TZD Green
92 Bx Gti BRG
90 Bx 16v Cream
01 Xantia 110 Hdi
90 Ax 1.0 Red
90 Bx 1.7 TZD Green
92 Bx Gti BRG
90 Bx 16v Cream
01 Xantia 110 Hdi
- x 8391
Are you local to these parts then?xantiagreen wrote:Carried out by a company in Wolverton Milton Keynes.
I don't live far from Wolverton...
For round these parts, that's not a bad price... Who did it. There's one garage in Wolverton I'd not trust with a pedal car, let alone a cambelt
- x 1488
Did the one on my Xantia HDi at 110k / 11 years.... it didn't look bad, but it ran better afterwards, and I wasn't petrified it was going to break every time I went out in it!
1.6 HDi is 10 years / 150k....did the C4 Picasso at 75k as it was noisy (many seem to go this way). 307 is on 104k / 8 years on the original belt....must get round to changing it
I think saying the 2.0 HDi is VERY easy is pushing it a bit Jim....
1.6 Hdi on the other hand....
- x 8391
OK, a fair cop RichardRichardW wrote: I think saying the 2.0 HDi is VERY easy is pushing it a bit Jim....1.6 Hdi on the other hand....
I also found the 2.0 16v HDi a pretty straightforward belt to do too, just as long as you're very careful not to rotate the engine backwards...
