How to change a heated mirror??
AirCooledHeaven
Locked user account
Unread post by AirCooledHeaven »
Hi, I'm trying to change a cracked heated driver's door mirror on a Synergie (fitted with electric folding mirrors). I can't for the life of me see how to access the back of the mirror to unclip it, there just isn't enough clearance between the plastic housing and the mirror itself. Am I missing something simple or is there a trick to this?
Stewart(oily)
x 35
Re: How to change a heated mirror??
Unread post by Stewart(oily) »
On many modern cars the mirror glass is held in with a wire circlip about 1.5 inches in diameter, on my Xantia I tilted the mirror back as far as it would go, then pushing a bit more and looking into the gap from above I could see the silvery clip, I persuaded it out of its groove and the broken mirror came away, the wire connectors were swapped, the circlip popped into place on the new mirror and it just pushed back on, my glass came from ebay and had a circular boss on the back to take the clip, surprisingly easy once you know whats in there.
SaabC5
Unread post by SaabC5 »
You generally need to tilt the glass so the bottom of the mirror is exposed from the underside. Some have clips that need prising off and others need to be "persuaded" with a screwdriver to come off. A cloth comes in useful to pry against to prevent damage on the mirror housing.
AirCooledHeaven
Locked user account
Cheers Stewart/Saab, while 'pushing a bit more' the mirror pinged off with the circlip intact. So job done.
