particle filter level low
citroenc5mad
Unread post by citroenc5mad »
Just got this message up on my speedo display, is it safe to use also how long before it needs filled.
Also anyone near Cambridgeshire or is willing to top it up and reset the computer and I will pay for services involved and help where I can.
Regards Dan
x 1996
Re: particle filter level low
Unread post by Stickyfinger »
It is not a panic, the level indicator is quite generous, needs doing but average miles you should be easy OK for a couple of weeks at least....and I am probable being pessimistic :)
Not up your way but check the Map/Lexia owners thread.
citroenc5mad
How much is average miles as I cover around 500 in a week.
qprdude
x 14
Unread post by qprdude »
Be good to have some details of your car, so the rest of forum members with same motors/mileage will know if we need to be thinking about topping up.
Rick.
2013 Citroen DS 5 D/Sport
citroenc5mad
Also what would happen is I topped it up before telling the ecu I have topped it up.
Would the car stop injecting it.
Also could I perform a full bsi reset and could this reset the ecu???
citroenc5mad
Its 2009 1.6hdi it has 84700 miles.
I averagely cover 500miles per week.
qprdude
x 14
Cheers. I read somewhere that around 80,000 miles is about the average before a top up is needed. I've a way to go yet. (I average 20 miles a week, except for the odd 1500 mile trip every few months)
Rick.
x 1996
Easy be OK for 1k miles I would think, that gives you two weeks. Any garage can top it up (best done on ramps I would think), you can then go to a members place and get the reset done.
citroenc5mad
Thanks for the replies will be ringing up some Tuesday hopefully get it done Friday.
Cheers again people.
citroenc5mad
Guys another quick question would a standard ODB reader reset it????
x 3296
No. The PSA group cars don't seem to get on well with generic readers (as I have found out).
Bandit12
x 12
Unread post by Bandit12 »
Hi Dan I'm in similar position and may be able to help. I have topped up the EOLYS and have been unssucessful to date in resetting the computer. The reason I've not managed to reset the computer is it appears to be u/s and I am searching for a replacement. Yes the low level message pops up on the screen every no and again but I have driven several thousand miles now and the car is fine with no error messages or loss of power. To reset the counter and computer you will need a lexia. Maybe there is someone near you on the forum who has one.
Bandit
2002 Citroen C5 2.2Hdi exclusive estate (sadly gone) :(
2009 Citroën C5 X7 2.0 hdi (136bhp) exclusive estate (Oh wow what an upgrade) 8-)
citroenc5mad
Mine has been on since the problem arose, everytime I start up pops the message.
I have booked her in at a local diesel specialist for Friday @ the cost off £185 for a top up and reset.
I have tried to contact my closest person on here to no avail so bit the bullet, I have really got to get my self a lexia been asking the misses for one for ages now so will have to get my own.
The garage I booked it in with also said it might be a wiring problem of some sort???
Will see what happens Friday when it goes in and when I get her back.
Cheers for the reply's guys
