Clio Mk2 ignition switch
Fake Concern
- x 65
My daughter's Clio Mk2 Ph1 Clio has a problem with the ignition switch. The key does not return when turned to the starter position on it's own. I imagine the spring has broken. Is this likely & can it be repaired or should I look for a new lock set?
