406 hdi throtle pedal ??
leeroy99
Unread post by leeroy99 »
hi all,
had my 406 110 hdi for a while now and hadn't really noticed but a few people have drove my car
& all commented on my accelerator been hard to press ?
ive since drove my friends 406 and throttle is very light and feels more responsive to myn ??
just wondering if anyone had any advice much appreciated thanks. :-D
BX
x 19
Re: 406 hdi throtle pedal ??
Unread post by BX »
The accelerator cable needs oil.
leeroy99
do you oil at the pedal ive squirted abit grease where the cable is under bonnet ?
thanks
BX
x 19
Unread post by BX »
No. The cable needs to be oiled. Disconnect the cable from the position sensor. Raise up the end and make a little funnel from plastic or aluminium foil. Pour in some light machine oil eg 3 in 1 or bicycle oil. Leave it for a period to travel down the cable.
leeroy99
thanks for reply appreciate it I will try & let you no how I get on thanks again.
leeroy99
hi sorted the cable did as you said & sprayed some duck oil down the cable and worked
the inner cable,
worked a treat like a new car thanks again
x 1996
Unread post by Stickyfinger »
little things make a big effect :).....gj
