Xantia fuel indicator (Low fuel)
Kumar9989
x 3
Unread post by Kumar9989 »
Any advice on how to fix this problem....with fuel indection on dest board....its always show low fuel.
After filing full tank...its show low fuel
Xantia 96 2.0 petrol auto
x 2008
Re: Xantia flue indicator (Low flue )
Unread post by Stickyfinger »
Sender is on the pump in the tank, maybe u/s or stuffed up with dirt....
x 8456
Re: Xantia fuel indicator (Low fuel)
It is easy to get to. let fuel get low, lift up rear seat, look for the big bung on the RH side and under here you can find the top of the sender/pump assembly held in the tank via a big round threaded collar. Disconnect, undo this collar with care and then lift the assembly out.
You will then see the sender float and potentiometer...
