C5 Tourer Clutch
jpn369
C5 Tourer Clutch
Unread post by jpn369 »
I have been told after my latest service that my clutch is nearing its wear limit.
Any advice on this-also if I am to replace should I get the DMF replaced as well?
x 1996
Re: C5 Tourer Clutch
Unread post by Stickyfinger »
makes sense to do so, water pump and cam belt kit the same time maybe as well.
How many miles on it ? what engine
x 1488
jpn369 wrote:I have been told after my latest service that my clutch is nearing its wear limit.
1. Ask them how they measured it!
2. Ignore them until it is actually showing some signs of being worn out, eg slip, judder, or noise on take up
jpn369
Sorry for delay- mileage is 120000.
SaabC5
Unread post by SaabC5 »
If its the original clutch then you'll almost certainly need a DMF as well. Mine was done at 136k and the DMF was mullered and the release bearing was in two pieces when we got the bellhousing off. You can get both on Carparts4less for just over £300, i opted for the LUK kit/DMF but interestingly the friction plate was marked up Valeo which is OE equipment. Its a mission of a job which books at approx 9 hours labour. Anybody who has done a Pug 407 will be familiar with the job however cos they share the same underpinings.
vborovic
Locked user account
x 40
Unread post by vborovic »
Me being at 136k (kilometers) with my car is slightly worried over this, if and when I get to the point of doing the procedure on the car (pricey, isn't it) ...
x 1240
Unread post by Peter.N. »
Is the clutch actually slipping? If not I wouldn't worry about it, how can they tell the clutch is nearing its wear limit? If its because the clutch pedal is high - they all are. Mine has done 200k+ and is still on the original clutch and DMF.
vborovic
Locked user account
x 40
Peter.N. wrote:If its because the clutch pedal is high - they all are.
This can't be applied to an auto gearbox
SaabC5
vborovic wrote:Me being at 136k (kilometers) with my car is slightly worried over this, if and when I get to the point of doing the procedure on the car (pricey, isn't it) ...
136km is a long way off 136k miles, don't worry about it just yet.
vborovic
Locked user account
x 40
I know, roughly 80k km ... but just reading about it is making me nervous ... :D
Richard_C
(Donor 2026)
x 230
Unread post by Richard_C »
vborovic wrote:I know, roughly 80k km ... but just reading about it is making me nervous ... :D
Reading anything invoving repair costs and a C5 makes me nervous!
Richard_C
x 1240
I wouldn't know, I don't believe in them. :wink:
lexi
x 133
Unread post by lexi »
I must say Peter, I am back into the way of the manual, after about 5 auto's. Nice light clutch and box the C5.
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
x 1240
I know they are ideal for people who drive in the city, but I don't, or at least very rarely. My main dislikes are the increased fuel consumption, the fact that they won't let you drive like you want to, although I believe they have improved in this respect, but the main reason is their relatively short life and the cost of repairs. I have repaired lots of manual boxes although nowadays they usually last the life of the car, but I wouldn't attempt an auto.
Another consideration for people of my age and older is that they are to easy to drive - possibly off a cliff or into a harbour. If your thinking is a bit slow a manual makes you engage your brain before putting the car into gear. :? :shock:
