hi lads is this definitely the afm gone as the hot wires look fine its also very clean
p101
engine speed 803 rpm
airflow ref 235mg/stroke
air temp 18 c
inlet air flow 53mg/stroke
turbo pressure 1012mbar
im also getting p0380
0 rpm
coolant 16 c
air 17 c
battery 12.1v
actual flow 39mm cubed/stroke
im also getting low voltage fault no code for abs oh by the way its a 2003 c5 2.0 hdi
please lads can you confirm p101
darbuck
- x 289
darbuck
- x 289
steelcityuk
Re: please lads can you confirm p101
Are you sure that's the OBD code, I thought they were generally 4 numbers. Also OBD codes are very generic, a test with a Lexia would be more informative.
Steve.
Steve.
not applicable
superloopy
- x 19
Google is your friend ... P0101 maf sensor issue as i think you know.
Sent from my LG-D855 using Tapatalk
Mike
Xantia Activa Dante Red MK1 (96) 121k - SORN, to be broken
Xantia Activa Silex Grey MK2 (98) 120k -SORN, ditto
Xantia V6 Silex Grey MK2 (98) 95k - non-runner
Xantia TD Storm Grey MK1 (95) 95k - non-runner
darbuck
- x 289
the above is a lexia readout just looking for a second opinion.
Darren
MikeT
- x 232
Only thing that stands out to me is low battery voltage. On a C5 I'm told this leads to all sorts of "faults" on it's own.
darbuck
- x 289
can a low battery exhibit this fault thats a nice c5 you have there mikeT
Darren
MikeT
- x 232
I couldn't say except I think it's worth ruling out battery/charging system due to that low reading.darbuck wrote:can a low battery exhibit this fault thats a nice c5 you have there mikeT
It might be normal (if the electrical system was sufficiently loaded).
