Xantia air con switch
Barry0allegro
Does anyone know why the air con switch in my poor old xantia is so dim? You can only tell if it's on in the dark! Can the bulb be replaced or does it need a new switch? Thanks for any help
Barry0allegro (Liverpool)
1997 xantia VSX auto
1997 xantia desire auto
1990 bx 1.9
1990 bx 1.9
- x 1996
Re: Xantia air con switch
This may help
http://xantia2.voila.net/interrupteurs_ ... e_bord.htm
- x 1443
The Mk1 switches have bulbs with green plastic filters. Over time the bulbs get a little dimmer, but the filters oxidise and turn nearly black.
If you can find a mk1 at the breakers, find a switch which is not illuminated very often (e'g. the alarm defeat switch) and it will have a bulb and filter in almost new condition.
The filter and bulb are reached through the front of the switch, it is best to practice dismantling on a spare switch first.
- x 1996
Inside an S1 and S2 switch
Note the opaque white diffuser and the leds fitted to the S2 switch.
With the diffuser removed and the leds (S2) exposed
My MOD, I removed the diffuser and fitted reflective foil
Barry0allegro
Thanks for the help folks will try with an lesser used switch
1990 bx 1.9
1990 bx 1.9
Zelandeth
- x 1592
Interesting. While the "on" light on my (S2) AC switch works, it's illumination doesnt...wonder if we have a dry joint in there. *adds to the "investigate on a rainy day" list*
Current fleet:
xf1ref
- x 12
At Xantia S2 the illumination green led's can be repleaced with some brighter..also for xantia s1 the bulb can be repleaced with a led serial with a resistance.
- x 1996
Taking a S1 switch apart......as it is fitted with a resistor, where is one added and how to get two brightness levels ?
xf1ref
- x 12
Well, for Xantia 1 is a bit different. When you turn on the lights the bulb is powered through the resistance and is less brighter.
I think that when you push the AC button the resistance is bypassed and the bulb is powered with full voltage ~14v and is more brighter.
You can try to get two brightness levels by powering one led through two resistance or by using two led's, one for each level of brightness.
tim leech
- x 12
My Desire 2 has the same issue, I have a fee spare switches so will swop one over and exchange the fronts.
1994 XANTIA 1.8i SX 132k, From new,
1985 BX 19GT the beige wonder
