Replace timing belt
xavchow
Replace timing belt
Unread post by xavchow »
Greetings all.. my 2008 C5 X7 is currently at 90,000km and i'm changing the timing belt and water pump.. any advise what else I should change along with it?
Also, i'll be buying the parts from from the local distributor .. are there any other parts that I should buy as well as part of the servicing process (eg. any engine gaskets etc..)?
x 1481
Re: Replace timing belt
Unread post by xantia_v6 »
Which engine does your car have?
xavchow
Its a 3.0l petrol. I think the es9a series
x 1481
xavchow wrote:Its a 3.0l petrol. I think the es9a series
My experience is with the earlier ES9J4, but the timing gear is fairly robust, and you probably won't need to change anything else.
xavchow
Thanks for the advice mate!
SaabC5
Unread post by SaabC5 »
Brake slave cylinder is one of those plastic jobbies and only £25 so worth changing while you have the battery/tray/trunking out.
xavchow
Thanks for the advice, and I have a cat just like yours =D
