how to adjust c5 suspension
darbuck
x 291
Unread post by darbuck »
Hi lads as you prably know ive been doing a bit on the back end of my mk 1 estate ive put everything back together and everything is working but the arse is sitting about 20mm lower than normal.my question is, How do i adjust the rear suspension using the height sensor
Darren
x 1999
Re: how to adjust c5 suspension
Unread post by Stickyfinger »
Via the clamp on the roll bar.....did you loosen it during your work ?
if not ?, have you got the dog bone on correctly ?
as always....car on a RAMP
dnsey
x 19
Unread post by dnsey »
Fine tuning of height can also be done via Lexia.
Easier and less frustrating provided your Lexia decudes to talk to the car!
darbuck
x 291
allright lads i had to take the clamp off as it was seized "always good axle stands no ramp lexia works fine however i think the discrepancy might be too much for lexia.
Darren
x 1999
I don't think you can do the adjustment on stands....the car needs to be level I think, 4 x ramps or a ramp-lift
darbuck
x 291
OK sticky cheers buddy
Darren
wurlycorner
x 271
Unread post by wurlycorner »
Yes, as sticky has said, adjust it via the clamp on the arb. Car needs to have all 4 wheels on the level with engine running.
Iain
CX DTR T2 Safari (silver)
