Stuck pin
mikehn
Stuck pin
Unread post by mikehn »
Hi all
Hoping someone has a clever idea to help me.
I am in the process of changing the boots on the rear suspension on a 1979 CX, problem is that I have a stuck pin on the ram, the drivers side slid out without a bother but the near side one is refusing to budge. I have sprayed loads of penetrating oil all around it, it did'nt respond to a pull, twisting or using a vice grips with a long screwdriver as a lever, it also didnt respond to various threats and swearing :-D
Any suggestions appreciated.
DickieG
Monaco's youngest playboy
x 38
Re: Stuck pin
Unread post by DickieG »
Heat might be the answer.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
c.morewood
x 55
Re: Stuck pin
Unread post by c.morewood »
I'm afraid Mike, after my experiences with the Xantia, that it may just be hours and hours of trying different things to punch it out with.. I tried nails, punches, long punches. pulling twisting, plus gas again and again, couldn't drill as I couldn't get a drill in there. thied to remove the whole rear strut but the bolt and nut were too rusty.. thats a future nightmare job,. I think it took 2 or 3 days of concerted effort to get one pin out. You just have to persevere it will come out eventually.honest.
Good luck
Tesla Model 3 LR DM AWD Blue White
'00 Xant 110HdiSX Est 83K "W"
'99 Xant 110HdiSX Est 320K "V"
'98 Xant 1.9TDSX Est 150K "T"
'97 Xant 1.9TD 20k Est
'94 Fiat TipoTd 40K
'85 BMW K100RT 330K Garaged 26yrs '80 Honda CB250 twin Superdream
x 1485
Re: Stuck pin
The bolt's not really a night mare - just lop the head off with an angle grinder, then push it out inwards. If it fouls something before it comes out, then 'just' cut it off behind the brake pipe, repeat till it comes free :-D
x 1240
Re: Stuck pin
Unread post by Peter.N. »
Had the same problem with my C5 (I have also had it with CX's and XM's). You need to find a punch that is almost exactly the same diameter as the pin, if you don't hit the whole surface area it spreads and gets tighter. I have a set of parallel punches that I got from ebay for not much money and always having the correct one is worth its weight in gold.
Heat my help but you can't use very much because the housing is alloy.
quintet
x 44
Re: Stuck pin
Unread post by quintet »
mikehn wrote:Hi all
Any suggestions?... strange as this may sound have you tried using 'brake fluid' as a penetrating oil...? its viscosity is basically so thin its capable of seeping into areas that an oil/lubricant (inc wd40 which i swear by) cannot penetrate.
When i heard someone suggest this for the first time i took it with a 'pinch of salt' so to speak but....these days i keep a spray bottle of (used) brake fluid to hand for anything that looks like its gonna be a :evil: to undo. It doesnt work everytime but weirdly it does seem to work although leaving the stubborn component to soak for as long as possible is obviously beneficial.
Music keeps me going.
