xantia window regulator
- My Cars: 1994 xantia 1.9 tdi sold on and still going strong 2ooo xantia 2.0hdi estate 1998 Renault megane 1.4
Hi All I need a drivers door window regulator for my xantia 2000 2.0 hdi 90 bhp estate, it needs to be the comfort model as the electrics are different on the continuous pressure regulator, I've tried eurocarparts and mr auto but they cant supply,, does anyone have any idea where I might get one other than main dealer. many thanks
Re: xantia window regulator
Hi, Bill. I don"t know what you mean by "Comfort Model", but you could try the "Window regulator man". They supplied the kit I needed to fix my 2000 90 estate. Mind you, only the plastic clip was any good ,but that was all I needed.
Hi shauny as far as I know the comfort model enables you to set the window where you want it, the continuous pressure model is just fully open or shut, and the units are not interchangeable, what you have is what you are stuck with, unfortunately the after market companies don't make the comfort model which is a lot dearer as it seems to be main dealer only, or that's what I have found, don't really want a second hand unit, thanks for your reply regards Bill
- chinkostu
- My Cars: N Xantia 1.9TD SX
03 Fiesta 1.4 Zetec - x 30
you're thinking of the one touch mode, servicebox only lists 2 different ones for each side depending on anti-pinch features. as far as i know the front drivers window has one touch across the whole range.
the one touch will let you put the window wherever by the way, you just press it harder and its manual mode, or press the button again and it stops
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Saxo 1.1 East coast
1999 Punto
1996 306 1.8 XN Auto
1996 Fiesta 1.3
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto
1996 Fiesta 1.3
