Waxoyl
Pug_XUD_KeenAmateur
(Donor 2018)
x 228
Waxoyl
I've got the opportunity to purchase an old 5 litre tin of Waxoyl. The tin clearly shows signs of age, but I expect its ok.
Can anyone reassure me that this stuff doesn't go 'off'....
...and if I shake the tin should it be thin enough that it'll slosh about?
....in a similar way perhaps to a tin of semi-synth engine oil?
Puxa
x 2000
Re: Waxoyl
Unread post by Stickyfinger »
Cannot see it going off if sealed. Wax and hydrocarbons need oxygen to oxidase. Just heat it for ages.
Decanting it into an old/cheapo thermos flask helps keep the heat in if your painting it on.
Pug_XUD_KeenAmateur
(Donor 2018)
x 228
Re: Waxoyl
thanks Sticky :)
Puxa
BX
x 19
Re: Waxoyl
Unread post by BX »
The wax may settle at the bottom of the can with the thinners on top. If it has give it a right good shaking to mix it all up. If it is in one of the round cans meant for the applicator then if you have a friendly paint shop they might oblige by giving it a shake on their mixing machine. If you need to thin it further use white spirit. I have used some very old waxoil in the past. It worked, ie 10 years on there is no rust.
x 1486
Re: Waxoyl
This is always worth a re-post (not me!) :rofl2: :rofl2: There are allegedly better products than Waxoyl, but nothing is better than free stuff 8-) .
Waxoyling...
I really wanted to get some of this into the Land Rover's chassis before I started using it. I had gone to halfords and bought 2 gallons, and knocked off work early.
I also had the real benefit that SWMBO was out so I had since 3.00pm been shoving the 2 gallon cans into the sink with near boiling water. I should have known things were going to go “slightly wrong” when I started.
I decided to use a Waxoil gun and my compressor, I had the propane burner on in the workshop since 3.00pm flat out and it was like the sahara, in fact it was so hot I decided a T-shirt and shorts was the dress code.
Grabbing some white spirit to further thin the waxoil I entered the kitchen and unscrewed the waxoil lid.
Thhhhuuuumpppppppp !…grwat big snotty big dollop spewed out over the kitchen worksurface... no probs I thought, ...I’ll sort that out when I’ve finished, as I might make "a little bit more mess yet".... glad she's not in.
Clutching hot waxoil injector thingy, part filled with waxoil and mixed with very very warm white spirit I squirted and soaked the chassis blasting away, and also practising holding my breath as it went misty in the workshop.
1 Gallon later I was nearly there, I was at the rear cross member, with yet another huge refill.
I ought to point out that I had also decided that at some of the angles I was at pulling and holding the trigger was a pain so I had devised a cunning lock of an elastic band on the trigger so that I could let it do it things whilst it sprayed away. Shove tube into hole and pull trigger… lock and waggle etc.
Enter the cat.
It sat there and looked at me the way only a cat can... it sniffed (unapprovingly) the dripped waxoil, and I said…
“Huh, you don’t want to be in here matey, this stuff will stick to your fur like brown stuff to a blanket”……and at that very point the jammed on tube extension came off the gun.
Could I release the elastic band round the trigger ? Could I XXXXXX.
The gun squirted warm waxoil/white spirit out at a force never so far experienced, one particularly good jet hit the cat, who bolted, knocking over the 2/3 empty (1/3 full!!) can of hot waxoil/white spirt mix, which flowed oh so well under the landy, and into my clothes T shirt and clothes and skin areas exposed..., but I was still fighting with the hot octopus trying to switch the damned thing off, but I failed, I was saved when it ran out.
Just when I thought nothing could get worse than lying under a Land Rover with waxoil soaked clothes, waxoil dripping onto my hair and face, and running into my ears... Some waxoil drpped onto the lead lamp... ping... Blackness.
It also pinged the fuse for the lighting circuit, getting myself out of the underneath of the landy proved friutfull, in that I knew all the places that waxoil had “leaked”.
Removing dripping clothes I entered house in “minimal Clothes” to resolve fuse prob, when Lights went on I saw the cat…
I AM GOING TO DIE IF SHE SEES THIS !
Here Puddie cattie……
This did not improve the sink/kitchen area one little jot, .....ever tried holding a 'waxoiled cat' in a sink with water and rags, and especially when cat does not enjoy it ?
1 hour later cat was scrubbed and very peed off with me, I’ve had 2 baths, and also cleaned the bath it seems that the bath will not be rusty...scrubbed kitchen floor, sink, worktop
Will she notice?
Cat stinks, garage sticks, alley way stinks, I stink, kitchen smells of lemon washing up liquid, which strangely we seem to nearly be out of, floor stinks.
She will be back any minute [gulp]. Nice job on the Landy tho....... ))
...later that evening...... Alleyway door closes and SWMBO walks in..... "have a nice time dear ?......." "what the HELL is that smell ?"
"Smell ?....er do you mean the waxoil ?" "Is that what it is - its disgusting" "Er..really"....
"yes really, the alleyway stinks, I mean I could smell it when I got out of the car..."
"er...really ?"
"yes, Really, I mean its stinking everywhere out, its even permutated the house " "really"
"yes really and [ picks up cat - I look away at telly and pray]...and ....good grief even the cat smells of it its ....[ at this point the cat growls.....probably hand enough of being "handled" during the evening...]..."WELL if your going to be like that madam you grumpy old thing" ...[places cat down firmly - cat grumbles some more].. cat exits still grumbling
"Charming... well... Anyway, have you finished?"
THOUGHTS...............
I've got away with it...."all done"...I've got away with it...."think I'll have a beer"...I've got away with it....I've got away with it...."Would you like a glass of wine ?"....I've got away with it....yippee....I've got away with it....and
SHE'S GOT THE HUMP WITH THE CAT TOO - NOT ME !!
Beer.... Bed.... RESULT....... !
But a bit close for comfort......far to close
x 2000
Re: Waxoyl
LOL>>>>>>>>>>>>>>>>>LOL
it is horrid smelly stuff
x 3306
Re: Waxoyl
:rofl2: :rofl2: :rofl2: Every time I read this! :rofl2: :rofl2: :rofl2:
daviemck2006
x 496
Re: Waxoyl
Unread post by daviemck2006 »
I will have to beware then! I have an old rusty unopened tin of waxoil which is destined for the underneath of one if not two old peugeots!!!!!!!
Skoda Karoq 1.6tdi 2018
Peugeot boxer 2016
In the family
C1 vtr+ 2010 daughter 2
wurlycorner
x 271
Re: Waxoyl
Unread post by wurlycorner »
:rofl2:
That is definitely one of those moments where you think " how the hell can all of this have gone so badly wrong in one go?"
Iain
CX DTR T2 Safari (silver)
addo
Sara Watson's Stalker
x 95
Unread post by addo »
I had a freak misadventure once, usual story - rushed repair job on some fancy furniture, got to be right, notice a tiny divot in the lacquer and carefully drip a toothpick point of clear into the mark; it melts in and flows out beautifully as I watch. Trust me; I'm a pro at this...
Then as I press the lid carefully back on my tin of clear two metres away, it goes "fwit!" with the air pressure and spits out a juicy big glob of clearcoat in perfect arc through the air, SPLAT! onto the finished article. #-o
So I can fully relate to the sort of story described above, with the caveat of a fortnight's wages hanging on the balance of a mishap.
Pug_XUD_KeenAmateur
(Donor 2018)
x 228
Re: Waxoyl
Thanks everyone for the advice and chuckles.
An aside, having just spent the last day or so diagnosing and fixing daughter's 106 D..... did you know that Fuel Priming Bulbs are no longer available, even at my local main dealers!!
....and the supposed 'Universal' one available at Factors / Motor shops etc doesn't fit, the fittings each end are too narrow to fit the pipe, the makers hadn't the sense to 'graduate' them, small to large. Fault was air in the fuel system and a sticky injector pump linkage. I got one from the scrappies in the end.
So presumably if you want a Fuel Priming Bulb for a diesel 106, 205, 306, 405, Saxo, Rover Metro, or any number of vans and other vehicles with the 1.5 or 1.9 diesel TUD / XUD in 'em, hard luck!! Charming, eh.
Puxa
x 5673
Re: Waxoyl
Ships chandlers and small boat services usually carry priming bulbs compatible with car engines.
Pug_XUD_KeenAmateur
(Donor 2018)
x 228
Re: Waxoyl
Thanks Steve, worth noting that
Puxa
Dormouse
x 696
Re: Waxoyl
Unread post by Dormouse »
RichardW wrote: 21 Jul 2015, 10:45 This is always worth a re-post (not me!) :rofl2: :rofl2: There are allegedly better products than Waxoyl, but nothing is better than free stuff 8-) .
Waxoyling...
Enter the cat.
Will she notice?
"er...really ?"
I hate cats but even I feel for this poor feline! If ever there was a cautionary tale of how not to waxoyl this is it. Can't stop laughing! You got away with that one by a whisker!
