Anti pollution fault
Dcourt
Hi I have just had the engine management light come on and an anti pollution fault come up on my 307 2.0 hdi! The day before I lost power and was restricted to 3000 rpm! Could anyone advise/help me on this problem
Cheers
Cheers
- x 1995
Re: Anti pollution fault
Yep....take it for a good run up the motorway for about 1 hour, keep it above 3k revs in 4th to get it really hot and the filters burning the soot.
Dcourt
Is it something to do with the fap filter?
- x 1995
Yes it is.....constant "town" driving is a problem as it does not allow a "regen" to take place (the cars BSI tells it when) because it never gets hot enough or the run is to short to build up the heat in the filter.....its called an Italian Tune-Up
Dcourt
Ok will give it ago! Any thing else it could be if it's not this?
- x 1995
Oh yes....there are "other" things ..... these are cars
but the run-out is a good start as this will check to see if all the systems are working......if not then unless you have the equipment its a garage job.
- x 1490
What age 307? The pre-2004 2.0 HDi 110 didn't have a FAP - later cars with the 136 BHP did. I would normally expect a 'Filter in danger of blocking' warning before the EML and limp mode came on. Did it come on when you accelerated hard, and when was the fuel filter last changed?
Otherwise you need to get it on Pug planet / diagbox to see what it's upset about. Might be someone near you with the kit: http://www.frenchcarforum.co.uk/forum/v ... 19&t=29178" onclick="window.open(this.href);return false;
Dcourt
It's a 2004 2.0 Xsi hdi 136 that has been chipped! Yeah it happened wen i accelerated hard! I'm hopefully getting it plugged in and checked tonight
- x 1490
So it's probably either a blocked fuel filter causing low rail pressure, or a turbo boost regulation fault causing high boost pressure. Most likely the former if it's not been changed for a while.
- x 1995
This can happen if the engine is cold.....did you boot it just after starting ?
Dcourt
Just went out in it and had no fault message and the engine management light has gone off!
Dcourt
No I was half way into an hour journey wen I booted it and lost power
- x 1995
I would still do a Fast 1/5 hour to make sure it does complete a Re-Gen....and it is "of the age" where a good code read would assist you to see where it has been throwing faults as prevention is cheaper
Dcourt
Would this problem cause some over revving when I put my foot down as it doesn't seem like a slipping clutch because pulling away is fine and don't get a clutch smell! Just happens every now and again when I put my foot down
- x 1995
No, the problem "pollution fault" would not cause over revving.
That will be your clutch slipping and will likely be in-need of changing/investigating, either way if its slipping it normally on it VERY LAST legs.
I refer you to this thread.....do not leave it till it goes Ping/Crunch/Grind/Pay-a-Lot
http://www.frenchcarforum.co.uk/forum/v ... =3&t=52847
Any oil dripping from under the car/gearbox ?
