I noticed that the pressure regulator clicks every 10-15 seconds. This doesn't change with each suspension setting. Does this indicate a faulty acculamator sphere? if so which of the following would be suitable for a 96 Xantia VSX TD Estate.
N45304 ACCUMULATOR SPHERE XANTIA ACCUMULATOR 18.65 or
N45392 ACCUMULATOR SPHERE-GEN XANTIA/XM (GENUINE CITROEN) 26.00
Another problem is that sometimes the back doesn't sink when you switch off the engine but next time you start it it drops fairly rapidly. See this thread http://www.andyspares.com/discussionfor ... IC_ID=5233 here. Would a new a new anti-sink sphere solve this or help it?
Ste
Acculamator sphere
AndersDK
Choose either [8D]
- as the text truly says :
One is an OEM sphere
The other is a genuine Citroen sphere
The difference ?
Packaging - and the double chevrons stamped on the genuine sphere [:)]
Both are brand new species -
If you want to join the lotto game - then ask for a re-newed sphere - which is even cheaper [:I]
Oh - BTW I agree it seems the accumulator sphere has gone flat on your car.
The difference ?
DarkendViper
