For some strange reason my 97 Athenas alarm has started going off at stupid times of the day for no apparent reason! On my earlier cars I just insert the key to disconnect the sounder under the screen but this isn't there!
At 3am in the pouring rain I had to resort to disconnecting the battery as no matter what I did it wouldn't shut off,
although it wasn't really loud! I had locked the car with the plip and set alarm and deadlocks and unlocked the same way.
Is there a fuse I can pull? I'm not bothered about having a working alarm but like a working remote!
Xantia Alarm Woes
tim leech
- x 12
Xantia Alarm Woes
1994 XANTIA 1.8i SX 132k, From new,
1985 BX 19GT the beige wonder
- x 1459
Re: Xantia Alarm Woes
Try using the ultrasonic defeat button, the ultrasonic transducers wear out and trigger the alarm. If that stops the problem, then it is better to disconnect one or both ultrasonic transponders in the doors.
Also check for damp carpets under the passenger seat.
chinkostu
- x 30
Theres a fuse for the alarm, its 13 on the series ones. Mine needed resetting as it kept going off, involved various battery disconnects and button presses. I'll try to find it.
The alarm key slot was only on early phase 1's. Doesn't even work on mine
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Saxo 1.1 East coast
1999 Punto
1996 306 1.8 XN Auto
1996 Fiesta 1.3
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto
1996 Fiesta 1.3
MikeT
- x 232
Proably the boot sensor causing alarm to go off (common problem apparently).
If you lock the car with the key (single turn only), it refrains setting the alarm in the first place. Not ideal but a workaround until you can fix the problem.
- x 1459
Being a mk1, the alarm is only activated if you deadlock the doors (second button on the remote).
MikeT
- x 232
...or turn the key twice in the doorlock.xantia_v6 wrote:Being a mk1, the alarm is only activated if you deadlock the doors (second button on the remote).
chinkostu
- x 30
Nah that only deadlocks the doors
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto
1996 Fiesta 1.3
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto
1996 Fiesta 1.3
- x 3296
It is likely (as has already been mentioned) to be the ultrasonic alarm component. I had this happen on my last car, and when I got a replacement that sorted it out. Apparently you can also temporarily overcome the fault by disconnecting the sensor on the passenger door.
tim leech
- x 12
I'll try that thanks,
Timmo
- x 168
is possible tim that the boot sensor is causing it, the Cam section ont he boot catch itself wears down over time and the sensor doesnt Always get pushed in, thus sometimes thinking its been opened and alarm going off!
i rectified this by not locking the car!
'58 C2 Code
'58 partner teepee outdoor
'58 C2 Code
chinkostu
- x 30
Easy way to see if its the ultrasounds is to hold the button on the dash until the led lights up then lock and alarm the car with the fob. This disables the interior sensors but not the boot/bonnet and doors
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto
1996 Fiesta 1.3
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto
1996 Fiesta 1.3
