Hello to all.
Have any of you had the following problem with CLIP ?
When loading CLIP it goes to 50% and a dialog box appears and it tells you that CLIP has not been updated for 57 days (or any number of days)
You click OK.
When you reload CLIP it fails to load.
You Un-install CLIP.
You then do the registry changes and re-install CLIP.
You rename the RSRWIN file and copy over the cracked RSRWIN file.
The cracked RSRWIN file will not run.
This is happening to us - we have disabled anti-virus, firewall , run CCleaner on the Registry and started again - still no good.
All suggestions gratefully appreciated.
CLIP and update problems
xsaras4ever
- x 44
Jumper 2.5d
406 Phase 2 Estate, Hdi
Fiat 500 (2009)
1997 Audi A3 tdi
Peugeot 205 td
Fordson Major Tractor
Nuffield 460 tractor
JCB 3cx
Fordson Super Dexta
Massey Ferguson 65
Fiat 500 (2009)
1997 Audi A3 tdi
Peugeot 205 td
JCB 3cx
Fordson Super Dexta
Massey Ferguson 65
Dave1987
Re: CLIP and update problems
Are you running CLIP software clone? The software does not allow to update online. I will load you a clear update/installation instruction.
http://blog.obd2express.co.uk/2015/10/2 ... clip-v152/
