jumping of timing of Peugeot 406
wolexjoe
New User
Unread post by wolexjoe »
What are the things to change in Peugeot 406 when its jump timing and bent the bigger 8valves out of 16valves.
Thanks jumping of timing of Peugeot 406
x 1463
Re: jumping of timing of Peugeot 406
Unread post by xantia_v6 »
A couple of questions to clarify the problem:
What year of car is it, and which type of engine is fitted?
Did the timing belt break, or did the timing just jump while running?
speedy3
Unread post by speedy3 »
first things first I would fit a new belt and do a compression test to see if it has bent any valves you might be lucky
