C5 X7 2.0 HDI 2008
Diagbox shows aircon OK (clutch OK, pressure OK)
Clutch fails to engage when AC button pressed.
When clutch engaged (using direct connection to battery) the compressor gets v. hot (my spit boils on compressor after 4 mins).
Just found the single radiator cooling fan has failed (open circuit across power connection).
Would this prevent the clutch engaging?
Also, what is the role of the smaller pins on the cooling fan motor?
Comments welcome.
Thanks,
Mike
C5 X7 Would failed radiator fan prevent aircon from working?
mikevybiral
DickieG
- Monaco's youngest playboy
- x 33
Re: C5 X7 Would failed radiator fan prevent aircon from work
Yes it will and the compressor is getting so hot due to excess pressure building up in the system because the heat in the gas not being dissipated through the condenser (A/C radiator) which in turn causes the system to over-pressurise and switch off to prevent damaging the system so personally I wouldn't run the A/C until the fan is repaired.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
mikevybiral
Just replaced fan assembly.
Aircon now works.
Thanks for contribution.
Mike
Aircon now works.
Mike
- x 1999
Where did you source your fan from ?, I may be in the same situation
mikevybiral
Bought new fan assembly (from NEAT on eBay) for £250.
Suggest you
1. Check relay (in box to R on fan) first.
2. Confirm fan u/s by disconnecting cables in box and removing relay. Then connect battery voltage directly to large feed connector and short out large relay sockets with a short length of garden wire. Alternatively, remove fan assembly, disconnect cables from motor, then connect 12V directly to large socket on motor.
NB1 no need to remove bumper.
NB2 don't close bonnet with no bonnet release cable connected!
Get back to me if you need more info.
Mike
Suggest you
Mike
DickieG
- x 33
Something tells me there's a story there,,,,mikevybiral wrote:NB2 don't close bonnet with no bonnet release cable connected!
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
mikevybiral
Just for once I saw it coming!
Made a temporary garden wire release loop through the grille.
Actually, it works quite well. I'll leave it for a while, just so people can say 'What's that ...?'
Mike
Mike
Dekidevil
- New User
How to remove and replace the cooling fan without rwmoving bumpermikevybiral wrote: 04 Jul 2015, 06:55 Bought new fan assembly (from NEAT on eBay) for £250.
Suggest you
Mike
- x 1999
Re: C5 X7 Would failed radiator fan prevent aircon from working?
You have to remove the bumper....
