Hi Guys
It sounds like the accumulator sphere on the white Athena is tired as the pump cuts in and out every few seconds, I have a sphere tool and have swopped plenty of spheres over the years but as this has hydractive is there anything different to worry about?
is it just the standard BX/Xantia accu sphere and exchanged in the usual way of putting it in low, undoing the bleed screw etc.
XANTIA TD ACCU SPHERE CHANGE
tim leech
- x 12
1994 XANTIA 1.8i SX 132k, From new,
1985 BX 19GT the beige wonder
superloopy
- x 19
Re: XANTIA TD ACCU SPHERE CHANGE
Yup ... simples as long as you dont undo the screw too far and lose the ball bearing.
Sent from my LG-D855 using Tapatalk
Mike
Xantia Activa Dante Red MK1 (96) 121k - SORN, to be broken
Xantia Activa Silex Grey MK2 (98) 120k -SORN, ditto
Xantia V6 Silex Grey MK2 (98) 95k - non-runner
Xantia TD Storm Grey MK1 (95) 95k - non-runner
tim leech
- x 12
Cheers Mike
I will give it a whirl.
tim leech
- x 12
Do you have to undo the pressure screw? Unlike in a bx it's hidden away behind many things and I just can't see the darn thing! I have the new accumulator and want to get it fitted.
If I drop the suspension and leave it overnight will that do? I've never des pressurised when changing wheel spheres just put it in low for a while.
Thanks!
Thanks!
- x 1481
Leaving it overnight, or pumping the brake 50 times should drain any pressure.
tim leech
- x 12
Cheers I'll try that
- x 3298
The pressure release bolt is on the regulator, the head is not flush to the regulator, and (IIRC) is 12mm. When you find it, only undo it by one revolution (if you take it out the sealing ball bearing will drop out, and drop you into a world of agro!).
tim leech
- x 12
Done!
Without needing to depressurise, I just left it in low overnight, my god was it tight, it's dripping though now so I will check the seal is located properly as it kept falling out! the fluid that came out had a definite orange tint to it which is concerning! So I'll do a lhm change ASAP.
chinkostu
- x 30
I had to do mine without a wrench on the car ramps. ended up taking the airbox and pipework out and using a long chisel to get it loose. not advised but there wasn't enough room to swing a cat underneath!
as for it dripping, the seal should be pretty snug into the regulator, mine definately showed no signs of falling out. theres not a bit of crud in the gap is there?
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Saxo 1.1 East coast
1999 Punto
1996 306 1.8 XN Auto
1996 Fiesta 1.3
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto
1996 Fiesta 1.3
tim leech
- x 12
I think the seal came out of the recess as I tightened the spheres up, I poked it back in but it doesn't appear to located properly, I will have another go later.
Old-Guy
- x 33
Been there
with a front corner sphere. The trick (Jim's?) is to stick the new seal into the groove on a new sphere with a little grease. So long as you don't use loads it won't do any harm as LHM is mineral based.
tim leech
- x 12
It appears the seal had fell out all together and was on the front subframe! Now put back together properly, I'm going to do a lhm change first though (although most of its on the floor!)
- x 3298
Oops, but at least you still have the seal.tim leech wrote:It appears the seal had fell out all together and was on the front subframe! Now put back together properly, I'm going to do a lhm change first though (although most of its on the floor!)
