C5x7, fan not on, Removing the bumper for access
x 2003
Unread post by Stickyfinger »
As it says....that will teach me to think I should give it a new radio !
SO, AirCon all Ok, heater works fine. 1st noticed problem when the aircon goes warm, check the temp and rising, then the STOP temp to high
Got home after a cool off period using the interior heater on full hot defrost (unpleasant), the car cooled itself when moving.
Cooled off all afternoon, Air-Con on, start.....No fan.
So, relays (where), I
cannot find a fuse listed,
? can I direct feed the fan to test it ?
So, this is problem No3 in short order, angry with it now and would rather not go back to that crappy dealer in Bath again if its simple.
vborovic
Locked user account
x 40
Re: C5x7, fan not on, overheat warning
Unread post by vborovic »
Is the fan behind the front bumper turning or not? If not, my dad had the same situation on his C5 Mk II, the solution was dismantling the front, accessing the fan motor, and having it sent to the electrical specialist that replaced the motor brushes (they were worn out, and could hardly turn the rotor anymore) ... pretty cheap solution if that's your situation
x 2003
Cheers,
The fan does not turn at all, it was yesterday :)
is it bumper off with the X7 ? or can you get to it via the top panel ?
vborovic
Locked user account
x 40
As far as I can tell from the repair procedure (for the engine cooler, but related to the fan), it is bumper off
x 1460
Unread post by xantia_v6 »
I don't pretend to know anything about the C5, but is there one fan or two? If two, and both have failed simultaneously, I would be suspecting a fuse, relay or wiring issue.
x 2003
Single fan
Bumper off.....RATS !
what about the fuse and relay, is that mentioned ?
vborovic
Locked user account
x 40
A quick glance didn't show anything useful ... the car's manual has the only mention of the fan for the Air Con, bonnet fuse box, position F11, 40A fuse ...
x 3566
The relay appears to be a maroon one not that far from the fan itself. It's quite possibly mounted on the fan framework - Cit Service isn't that clear. P/N 6545N3 / 6545XF
dnsey
x 19
Unread post by dnsey »
Before doing anything more drastic, check if the fan is seized - very common on earlier models.
Easy enough - just allow time for the car to cool, so the fan doesn't start running unexpectedly, then poke it with a stick!
The blades should turn freely.
x 2003
The fan relay is a 40amp one, I wonder what fuse protects the fan then ? the same one cannot do as the aircon works great until it got hot.
Thanks again for looking.
With all this "can bus" crap you would think a failed cooling fan would throw a warning....everything else does :)
PS. Do you know about steering wheel patch leads to a Sony or Pioneer ?
x 2003
The Fan turns free and easy, no rubbing or grinding noise, free spinning. It did not fire on cold start with AirCon on (which works very well btw).
dnsey wrote:Before doing anything more drastic, check if the fan is seized - very common on earlier models.
x 3566
Stickyfinger wrote:The fan relay is a 40amp one
Cit Service has it as a 50amp relay - but that's using my '09 2.0 manual car as a reference.
Stickyfinger wrote:PS. Do you know about steering wheel patch leads to a Sony or Pioneer ?
Not me guv... but I might have an old Autoleads Xantia to Sony one lying around somewhere that you can have if you're still looking to upgrade your other 'ongoing project' :)
x 2003
Ta....Cit service says 40amp for mine, looking at it I may be able to get to the relay via the top panels, after the morning job I will have a go and ID it. There is so much space in there vrs the Activa :)
On the patch lead....I was really asking Vborovic as he seems to be very able with stuff that sparks :)....but yes, if you have one I would like to take you up on that as one of the head units I have just stolen on ebay (love to snipe) to be fitted to the Xantia....PM me the amount you want.
Ta ducks
x 3566
Stickyfinger wrote: On the patch lead....I was really asking Vborovic as he seems to be very able with stuff that sparks :)....but yes, if you have one I would like to take you up on that as one of the head units I have just stolen on ebay (love to snipe) to be fitted to the Xantia....PM me the amount you want.
Ta ducks
If I can find it, you can have it for free, gratis and for nothing.... I just need to find it ! I've got some old XM, Pug and Renault ones kicking around somewhere as well.
vborovic
Locked user account
x 40
Not sure, I don't think I've seen any steering wheel patch cables for the 2008+ C5 ... the steering wheel is too complex compared to the previous C5s, maybe that's why no one bothered to make one ... will need to look into chinese sites, they're pretty crafty with stuff like that ... :D
