Xantia Radio Driving Me Mad
tim leech
x 12
Unread post by tim leech »
Hi Guys
My newly acquired lovely mileage 97 S1 Xantia Athena has a very annoying problem, the factory fit top spec radio is constantly searching for stations no matter what I do, it keeps switching from LO (local) to DX and then never stops searching for stations no matter what button I press! I have set the stations as I want them but even when I press them it goes to that station for 5 seconds and then goes off searching again
1994 XANTIA 1.8i SX 132k, From new,
1985 BX 19GT the beige wonder
Mandrake
x 695
Re: Xantia Radio Driving Me Mad
Unread post by Mandrake »
tim leech wrote:Hi Guys
Haven't had this happen, but my first guess would be a fault in the wiring loom (such as a pinched/shorted wire) between the radio and the steering wheel buttons causing the radio to think one of the buttons is held down permanently.
I'm not sure if its possible, (ie, a separate plug to the power and speakers) but if you can, try disconnecting the cable that goes to the steering wheel to see if the problem stops - if it does then you may just need to trace the wiring and look for damage or check the buttons in the steering wheel.
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
elma
x 287
Unread post by elma »
Have you got signal on any of the stations?
The aerial lead has a connector under the passenger carpet that can come unplugged.
If it does it even when you set it to tape I expect what Mandrake said is more likely though.
tim leech
x 12
Cheers chaps, actually the stations are very clear, its like the unit is automatically switching from local (LO) to DX (distance) automatically and then goes of searching, maybe for a stronger signal? Is there a way to turn it off I wonder?
It does it even when the ignition is off!
I really hope I don't have to change the radio the display is working fine as is all the bulbs and functions! :cry:
x 1448
Unread post by xantia_v6 »
Does the station-skip buttun >>| on the steering wheel do anything? It normally provokes exactly the behaviour you describe (scanning around the presets with a 5 second wait on each one), but normally you have to actually press it to start the process!
tim leech
x 12
Yes it does work
x 2941
I'd suspect the antenna, the radio is searching for signals that aren't there or strong enough because the antenna or its cable is damaged.
tim leech
x 12
Ok Gibbo, I will swop the mast over for a known good one.
Cheers
x 1448
The radio won't change station because of a weak signal (it will switch to another transmitter of the same station), so you can discount the antenna. I think that it is either a faulty head unit or a fault in the steering wheel controls.
Note that that system has an amplifier build into the base of the antenna (not relevant to your current problem) which can be a puzzling source of poor radio performance.
DickieG
Monaco's youngest playboy
x 38
Unread post by DickieG »
Hi Tim, have you tried pressing the AF button? IIRC that button turns on/off the auto tune/RDS on the radio.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
tim leech
x 12
Yes mate I have
c.morewood
x 55
Unread post by c.morewood »
Have a feel under the passenger compartment carpet and see if the footwell next to the tunnel is wet.. that caused my S2's radio to start hissing and loning for stations.
Tesla Model 3 LR DM AWD Blue White
'00 Xant 110HdiSX Est 83K "W"
'99 Xant 110HdiSX Est 320K "V"
'98 Xant 1.9TDSX Est 150K "T"
'97 Xant 1.9TD 20k Est
'94 Fiat TipoTd 40K
'85 BMW K100RT 330K Garaged 26yrs '80 Honda CB250 twin Superdream
addo
Sara Watson's Stalker
x 95
Unread post by addo »
I've seen a few devices that include conductive contact pads on a "rubber" membrane, do this sort of thing. If it stops with the steering wheel controls unplugged you have a culprit...
x 1998
Unread post by Stickyfinger »
Tim, if you need some "parts" for yours like a button controls/pads etc, let me know and you can have my old code less unit (with busted tape player) one to pick apart
tim leech
x 12
cheers chaps, I will change the radio mast, base and check the connection under the seat.
I could retrofit a modern unit but I like the factory look and tbh its a good piece of kit which my ipod connects straight into.
