C5 Spheres - When should they be renewed?
hamster99
Unread post by hamster99 »
Just wondered when should the suspension spheres be renewed, or do they last forever? :rofl2:
My C5 is now on 250k, the last 85k with me and the service info says nothing about spheres.
Rob
22 C4 1.6 eHDI Shine Plus
67 RR Autobiography 4.4 SDV8
15 C4 1.6 eHDI 115 Exclusive - fond memories
12 RR Westminster 4.4 TDV8 - Gentleman's Club on wheels
05 C5 2.0 HDI 138 Exclusive - gone but not forgotten
05 C5 2.0 HDI 138 VTR - crushed May 2015
Homer
x 16
Re: C5 Spheres - When should they be renewed?
Unread post by Homer »
I guess the answer would be - when it needs them.
Clogzz
x 40
Unread post by Clogzz »
Not quite forever, but mine are still good after 12 years.
The rear ones can be tested for springiness by pushing down on the boot.
The front ones should give the same damping as the rear ones when going over bumps.
dnsey
x 19
Unread post by dnsey »
Apparently, wnen the pressure gets too low, an internal spike punctures the diaphragm, so they're either OK or shot.
x 2008
Unread post by Stickyfinger »
Just go to one of the specialists and have them checked/re-gassed...unless you know someone who can :), no reason to get new if you can re-gas.
Taking them off is the only real way of checking (unless flat and spiked)
katanassn
Unread post by katanassn »
When they fail what problems do they cause?
hamster99
Thanks all, I'm asking mainly because I think the ride is a bit harsher than it used to be.
Good news if I don't have to replace them and I didn't know you could get them re gassed either.
Rob
Homer
x 16
katanassn wrote:When they fail what problems do they cause?
The effect is the opposite to shot dampers on a conventional suspension, the ride will go rock hard with no bounce at all.
x 2938
Like a VW Golf. :-D
Clogzz
x 40
There have been spheres exploding from excessive loads ... but the spike will now prevent that. :twisted:
Zelandeth
x 1611
Unread post by Zelandeth »
Basically the ride will get progressively bouncier (more like a conventional car with knackered shocks) before then going rock solid when the sphere is completely flat.
When the front ones on my Xantia were shot (but still had some gas in) bouncing either corner resulted in five or six bounces before the car would settle. New spheres resulted in it settling on the first bounce again.
Current fleet:
07 Volvo V70 SE D5, 89 Ford Thunderbird, 85 Sinclair C5, 84 Trabant 601S, 73 AC Model 70, 62 Rover 110.
wurlycorner
x 271
Unread post by wurlycorner »
dnsey wrote:Apparently, wnen the pressure gets too low, an internal spike punctures the diaphragm, so they're either OK or shot.
:shock: Really?
Iain
CX DTR T2 Safari (silver)
SwissSPEC
Unread post by SwissSPEC »
I've seen the inside of a c5 sphere, from memory i think there are 4 spikes, not quite sure why they made them like that??
CX GTI 2 Turbo (LHD) - Sorn
Bx Gti 16v
BX TZD Turbo - Sorn
C5 Mk1 LX 2.0HDi Estate
Mini Cooper D Clubman
x 2008
Avoids insurance claims by not permitting re-gassing of (what they call) failed spheres
